Old 16-07-2009, 09:18 PM   #1 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Hardware Recommendation for new PC
OK, so finally parents agreed upon upgrading the age old home PC. The budget is set at Rs. 35000. And within this limit, the highest performing PC is my target. I have set my mind on the following configuration. Please clarify if there are better alternatives available.
  • Processor: AMD Phenom II X2 550
  • Motherboard: Gigabyte GA-MA770T-UD3P
  • RAM: Corsair TW3X4G-1333C9 4GB Kit
  • Graphics Card: AMD ATI HD 4770
  • HDD: Seagate Barracuda 7200.12 500GB
  • CD/DVD: Nothing specific in mind, I should choose one of the better ones based on SATA.
  • Cabinet & Power Supply: Those are two things I couldn't set up my mind yet. I want the best available option under my budget and judging other components I think it'll take at least a 600W or 650W PSU. Recommendations are welcome.
  • Display: Dell UltraSharp 1909W 19-inch Widescreen Flat Panel Monitor. It can be seen here @ http://bit.ly/CshYn
Please inform me if the quoted configuration can be achieved within my budget of Rs. 35k. Any other possible configuration within the limit having better performance is also welcome. I'm going to buy this on July/August this year.
debsuvra is offline
Old 16-07-2009, 09:30 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Hardware Recommendation for new PC
Get GTS250 instead of HD4770.
desiibond is offline
Old 17-07-2009, 06:12 AM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Thumbs down Re: Hardware Recommendation for new PC
I guess you also have Sapphire HD4770 yourself. Still you're recommending GTS250 over it? And as far as the benchmarks on several reputed hardware sites go, HD4850 and HD4770 really put GTS250 in backrow. And GTS250 is expensive than the rest too.
debsuvra is offline
Old 17-07-2009, 07:10 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Yes I do have HD4770 because at that time HD4770 was 7k and GTS250 was 10k. Now GTS250 is avaiable for 7k and HD4770 is at 7.5k-8k. GTS250 is faster than HD4770 and HD4850.
Old 17-07-2009, 11:00 AM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Hardware Recommendation for new PC
Well, if you are worried about the price, I can assure you that HD4770 is still cheaper than GTS250. And gaming benchmarks show that there are not much differences between these two. On the other hand, HD4770 is based on newer technologies like 40nm and GDDR5 memory. It also has more shader units than GTS250.
debsuvra is offline
Old 17-07-2009, 11:32 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
no yaar. GTS250 has more power under the hood.
anyways, forgot that you are going for a 19" display, in which case, get the one that is cheaper.
Old 17-07-2009, 11:49 AM   #7 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Question Re: Hardware Recommendation for new PC
Can you share links to some benchmarks or something that support your claim?
debsuvra is offline
Old 17-07-2009, 12:25 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
http://www.guru3d.com/article/ati-ra...4770-review/14
http://www.techpowerup.com/reviews/ATI/HD_4770/12.html
http://www.overclockersclub.com/revi...e_hd4770/9.htm
http://www.techspot.com/review/163-r...770/page8.html
http://www.tomshardware.com/reviews/...0,2281-11.html
http://www.hardwarecanucks.com/forum...-review-9.html
Do you want more?
Earlire, HD4770 was hot product coz it's 40nm and is 3k-3.5k cheaper than it's nearest competitor and now, there is no difference in price between HD4770 and GTS250 and HD4850. and the performance difference is clearly noticeable between HD4770 and GTS250 in most games and so, why not go for GTS250
Also, when it comes to driver support for gaming or linux, nvidia is leagues ahead.
Old 17-07-2009, 01:02 PM   #9 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Do you want more?
I still don't see any noticeable differences between two in games like Crysis. And the monitor I'm getting just supports the maximum resolution of 1440x900.
Yeah, that's a good point. I liked nVidia for that reason for ages. I would get a nVidia and an Intel if there was no limit of Rs. 35k.
debsuvra is offline
Old 17-07-2009, 01:09 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
an increase in fps from 27-28 to 32-33, though is little, does bring huge difference in smoothness and in gameplay. 30fps is like the mark at which the gameplay becomes smooth without any lag.
at same price point, even a 5fps increase in perfomance is worth.
anyways, it's your wish.
Old 17-07-2009, 01:21 PM   #11 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Cool Re: Hardware Recommendation for new PC
You're right about it. OK, I'll look into it. 8)
debsuvra is offline
Old 17-07-2009, 11:55 PM   #12 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
By the way, how about an Intel solution comprising of Intel Core 2 Quad Q8200 and nVidia GTS250?
debsuvra is offline
Old 18-07-2009, 12:25 AM   #13 (permalink)
Excessive happiness
furious_gamer's Avatar
Dont go for Q8200 unless you're into heavy multimedia applications. For gaming E8400 is a lot better than Q8200. If u still want Quad core go for Q9xxx series.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 18-07-2009, 12:53 AM   #14 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Intel Q9xxx series is way over my budget. It's either Phenom II X3 720 or Core 2 Quad Q8200.
debsuvra is offline
Old 18-07-2009, 01:14 AM   #15 (permalink)
Excessive happiness
^^Then go for Phenom II X3 720.....
PS Request
Old 18-07-2009, 07:44 PM   #16 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Angry Re: Hardware Recommendation for new PC
People are also recommending Intel Core 2 Duo E8400. What about that? I'm really confused, dude.
debsuvra is offline
Old 18-07-2009, 08:36 PM   #17 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@debsurva, you now have the choices in your hand. Pick one that you feel suites your needs.
Old 18-07-2009, 09:37 PM   #18 (permalink)
Cool G5's Avatar
@Debsuvra - Finally it boils to what do you wish to use your machine for. Just saying highest performing machine tells nothing.
I recommend you an Intel Setup with E8400 which performs good in gaming. The Quad Q8200 will help you in application & games supporting multi-core processing which is somewhat futureproof.
Cool G5 is offline
Old 18-07-2009, 11:29 PM   #19 (permalink)
Excessive happiness
+1
Q8200 - Future proof
E8400 - Play games till all developers start to optimize the games to use four-coures.
PS Request
Old 19-07-2009, 12:48 AM   #20 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
+1
Q8200 is just an entry level Quad Core and it has nothing special to be future proof. While E8400, though not future proof in terms of multi-threaded applications, will perform much better for at least next 2 years. I'm going for Intel E8400. FINALIZED.
debsuvra is offline
Old 19-07-2009, 09:50 AM   #21 (permalink)
Excessive happiness
A wise choice.
PS Request
Old 19-07-2009, 10:58 AM   #22 (permalink)
paroh's Avatar
Please suggest me a good config. for gaming pc for my friend max Rs 40000 and please indicate the price of the products also
1.Processor (INTEL only)
2.Motherboard.
3.Graphic card (That can able to play Crysis at decent frame rate at higher resolution)and please also tell if the card is able to play Crysis will it is also capable of playing the lateast games at higher resolution with decent frame rate.
4.Hard disk (seagate 500Gb)
5.PSU
6.RAM (4GB)
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
Old 19-07-2009, 02:13 PM   #23 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Talking Re: Hardware Recommendation for new PC
2.Motherboard.
5.PSU
6.RAM (4GB)
Thanks for hijacking my thread. Why don't you create your own thread to get recommendation?
debsuvra is offline
Old 19-07-2009, 02:24 PM   #24 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
your choice is perfect for you budget...
for smps a corsair vx550w ... will be enough
for mobo: also take a look at msi 770-C45 & 770-C35
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 21-07-2009, 10:57 AM   #25 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
OK, so here's a increase of total budget to Rs. 50k (including VAT). My proposed build is given below,
  • Intel Core 2 Duo E8400
  • MSI P43NEO-F
  • Corsair TWIN2X4096-6400C5 4GB Kit
  • Palit GTX 260 Sonic 216 SP
  • Seagate 500GB SATA
  • Samsung SH-223
  • GlacialPower GP-AL650AA
  • Coolermaster Elite-330
  • Benq 21.5" G2220HD LCD
  • Microsoft Intelli Explorer 3.0
  • Microsoft Wired Keyboard 600
Any thoughts on this build?
debsuvra is offline
Old 21-07-2009, 11:05 AM   #26 (permalink)
Bond, Desi Bond!
desiibond's Avatar
looks like Intel is doing price cuts. wait!!!
Old 21-07-2009, 02:42 PM   #27 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Are you sure on this?
debsuvra is offline
Old 21-07-2009, 02:53 PM   #28 (permalink)
Bond, Desi Bond!
desiibond's Avatar
oh yes.
http://techpowerup.com/99736/Intel_P...rice-Cuts.html
Old 21-07-2009, 08:01 PM   #29 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
I'm now eyeing Core 2 Quad Q9400 instead of my first choice Core 2 Duo E8400. They are similarly priced now.
debsuvra is offline
Old 22-07-2009, 11:31 AM   #30 (permalink)
Excessive happiness
Then go get the Q9400, when they both available at same price.
PS Request
