How do you find out if your computer is 32 bit or 64 bit in Windows?
Windows XP
If you have Windows XP, there are two methods to determine whether you are running a 32-bit or a 64-bit version. If one does not work, try the other.
Method 1: View System Properties in Control Panel
1. Click
Start, and then click
Run. 2. Type sysdm.cpl, and then click
OK. 3. Click the
General tab. The operating system appears as follows: • For a 64-bit version operating system:
Microsoft Windows XP Professional x64 Edition Version < Year> appears under
System. • For a 32-bit version operating system:
Microsoft Windows XP Professional Version <Year> appears under
System.
Note <Year> is a placeholder for a year.
Method 2: View System Information window
1. Click
Run. 2. Type winmsd.exe, and then click
OK. 3. When
System Summary is selected in the navigation pane, locate
Processor under
Item in the details pane. Note the value. • If the value that corresponds to
Processor starts with
x86, the computer is running a 32-bit version of the Windows operating system. • If the value that corresponds to
ia64 or
AMD64, the computer is running a 64-bit version of the Windows operating system.
This information has been taken from
http://support.microsoft.com/kb/827218
for vista follow above link.
