Old 10-07-2009, 04:40 PM   #1 (permalink)
Default Need Help
Dear All
I have been using Vista Home edition on my Compaq laptop. In the My Doc folder there are following files which have been sitting there for ages and have not caused trouble but I would appreciate if someone explain what they are and if they could be removed without causing any problem :
ntuser.dat 10.07.2007 3584kb
ntuser.datLOG1 256kb
ntuser.datLOG2 0kb
ntuser.dat{45b4..............} 64kb
ntuser.dat{45b4..............} 512kb
NTUSER.DAT{.................} 64KB
NTUSER.DAT{................] 512KB
NTUSER.DAT{................} 512KB
ntuser.ini 1kb
And
g2mdlhpx.exe
Thanks & best regards
harmads is offline
Old 10-07-2009, 05:01 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Need Help
Don't remove them. Instead change your folder options not to show system files.
desiibond is offline
Old 10-07-2009, 05:06 PM   #3 (permalink)
S60 rocks
rajhot's Avatar
They r some reg files...don't play with them.
Check these links
http://www.vistax64.com/general-disc...dat-files.html
http://answers.yahoo.com/question/in...0023440AAPuo2f
Proud Owner of N82! :cool:
rajhot is offline
Old 11-07-2009, 05:31 PM   #4 (permalink)
Thanks Desiibond for your reply. However I tried to customize this folder and message box said Properties for this folder is not available.. This is the My Doc folder on the desktop
Thanks rajhot. I tried both links but could not get to how to hide these files.
harmads is offline
