Old 27-06-2005, 11:41 AM   #1 (permalink)
I draw every day
yash's Avatar
Default pc running too slow
my pc has been running too slow of late.i have lots of songs and softwares downloaded on my pc.i have all the latest updates 4 winxp and antivirus/antispyware softwars. so i DONT WANT TO FORMAT/REINSTALL XP.what else can i try to make it as fast as it used 2 b.
Kisne roba mera tobat.
yash is offline
Old 27-06-2005, 12:48 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
1st thing is Defrag ur Hard Drive... it will take long if u r on FAT32 but do it... its worth of time....
then try 3rd party softwares like System Mechanic Pro....
mate as the day goes by... we see others system... too faster than ours... u think that our system is running slow... but thats not the case... as it is running slow compair to the fast systems that we r looking at.... keep this thing also in ur mind....
Choto Cheeta is offline
Old 27-06-2005, 01:49 PM   #3 (permalink)
expertno.1's Avatar
dude use Dr. Salmans window power tools
1)use 3rd party softwares
2)defrag ur hard drive
3)use reg cleaner
4)unistall unwanted programs
5)disable windows error reporting
6) increase ur virtual memeory
7)set the system memory use value to "system cache"
8)increase ur ram
9)if possible make ram drive
10)run scandisk
expertno.1 is offline
Old 27-06-2005, 02:18 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
first, remove junk files. clean registry, remove invalid shortcuts, etc. for this use ace utilities or tune-up utilities or system mechanic.
then defragment your registry using any one of the last two mentioned above.
check up your start-ups. and remove those u dont require. why have them starting up unneccessarily, if u dont require them. u could control them thru the winxp/sp2 utility 'startup control panel' or winpatrol.
defragment your boot-files using bootvis. optimize your cache using cacheman. else use "driverheaven's tunexp".
check out : http://www.thinkdigit.com/forum/view...845&highlight=
disable services u dont need.
check out : http://www.thinkdigit.com/forum/view...415&highlight=
scan your pc for virus/spyware.
tweak ur xp for squeezing out maxm performance. tune-up utilities has some good tweaks.
use scandisk/checkdisk utility.
lastly defragment your disks.
most of above avlble at www.download.com.
have fun, fellow pune-ite !!!
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 27-06-2005, 02:23 PM   #5 (permalink)
Just Do It
Charley's Avatar
Since u've got tons of data stored, wudnt be a bad idea to scan for viruses and trojans as it slows down the PC , also later it doesnt open up any progy with all kinds of errors and then u have to format.
cheers
Charley is offline
Old 28-06-2005, 09:56 PM   #6 (permalink)
I draw every day
yash's Avatar
i said i had the latest virus and spyware definitions. i have checked them and removed 4spywares recently.but didnt get any results.one thing that could be the reason is that trend micro`s default action on detectin a virus was deny access.so lots of viruses are stored on my hdd but i cant delete them because i cant even see them after it has denied access.what can i do about them?also i have checked the startups by "msconfig" utility. only the antivirus is on startup and some required drivers.no additional softwares like messengers etc.
yash is offline
Old 28-06-2005, 10:41 PM   #7 (permalink)
hi First of all tel me
1 How to disable windows error reporting ?
2nd
2 How to set the system memory use value to "system cache" ?
3rd and most wanted
3 What is RAM drive AND How to MAKE RAM Drive ?
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
imprince is offline
Old 29-06-2005, 07:32 AM   #8 (permalink)
q3_abhi's Avatar
Use Game XP, I think it will considerably increase your Windows Performance. Its there in June DvD of DIGIT. You may also use System Mechanic Pro for removing Junk files,defragmenting,duplicate files,registry cleaning, recovering data etc. Its a good all-in-one software. Set your Windows XP theme to Classic. Right click on My Computer,properties,Advanced,in Performance-Settings n set it to "Select for the best performance".
-The above things will surely increase your performance.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 29-06-2005, 08:13 AM   #9 (permalink)
rajesh's Avatar
right click on my computer,select properties
then click on advanced ,and click on button "error reporing"
and select the option button: "Disable error reporting"
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 29-06-2005, 08:15 AM   #10 (permalink)
vishal_bhatia87
Posts: n/a
To disable error reporting visit here
http://www.thinkdigit.com/forum/viewtopic.php?t=23717
Old 29-06-2005, 11:32 AM   #11 (permalink)
tnx but what about remaining questions
im repeating :--------------
3rd and most wanted
_________________
जय माता दी
imprince is offline
Old 29-06-2005, 12:49 PM   #12 (permalink)
Just Do It
Charley's Avatar
Download softwares like Avast, Antivir, Ewido, KAV update the defintions and scan ur system. They remove most of the known threats..
BTW do a hijack and post the log here .....
Charley is offline
Old 29-06-2005, 01:56 PM   #13 (permalink)
I draw every day
yash's Avatar
man the forum link just deals with the start-up issues.
what`s really buggin me is the programs dont start 4 like 2 mins after i`ve clicked on them.i mainly use firefox and ragnarok.i connect to the net and start these and they do not appear for abt 3 mins. what do i do bout this?
the last hope is reg cleanin.will do that too as ace utilities is downloaded
yash is offline
Old 29-06-2005, 03:17 PM   #14 (permalink)
I draw every day
yash's Avatar
u mean get another antivirus to scan for the files that that pc-cillin has blocked?
btw a new development in the case, i noticed that the opening of ragnarok and mozilla,internet explorer was just slowing down after the internet was connected.and as soon as i disconnect it, the programs just pop up.
so i checked the task manager and found an unknown process when the net was connected"GIANT antispyware updater.exe"
I dont have any GIANT antispyware installed on my pc.i only have microsoft and spyware doctor installed.and only microsoft is running at startups.spyware doc only runs when i execute it. so what is this giant antispyware updater?
yash is offline
Old 29-06-2005, 08:49 PM   #15 (permalink)
3rd and most wanted
_________________
firends what about my questions ??????????
जय माता दी
imprince is offline
Old 29-06-2005, 09:39 PM   #16 (permalink)
expertno.1's Avatar
2. right click on my computer then properties
then go to advanced tab
the virtual... settings
advanced tab
there is the option
3. use Tweak xp to make ram drive
Old 29-06-2005, 10:23 PM   #17 (permalink)
advanced tab
there is the option
what is RAM drive ? what is da function of ram drive , how it is different from virtual memory ????????????????
जय माता दी
imprince is offline
Old 29-06-2005, 11:36 PM   #18 (permalink)
abhishekkulkarni's Avatar
Programs do not start for 3 min(180 secs) ?
Please give us your rig configuration.I am sure we can help you after that.
May the source be with you ..
abhishekkulkarni is offline
Old 30-06-2005, 12:21 AM   #19 (permalink)
Ashwin Saxena
Posts: n/a
Try all things mentioned above If problem not solved than increase ram amount.
Old 30-06-2005, 10:16 PM   #20 (permalink)
advanced tab
there is the option
Friends pl tell me what is RAM DRIVE and how it is different from Virtual Memory ? nd how to configure RAM DRIVE ?
जय माता दी
imprince is offline
Old 30-06-2005, 10:29 PM   #21 (permalink)
Ashwin Saxena
Posts: n/a
Well I think RAM Drive cant do anythink to speed up PC.
Old 30-06-2005, 10:55 PM   #22 (permalink)
OK , but my friends what issssssssssssssss Ram Drive I just want to know
what the hell is this RAM DRIVE ?
sorry but ............................!!!!!!!!!!!!!!!!!!!
जय माता दी
imprince is offline
