View Poll Results: D Difficulty level
easy 0 0%
medium 0 0%
hard 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 06-07-2009, 09:16 PM   #1 (permalink)
sagnik_bose's Avatar
Exclamation Heur Trojan
i'm running a computer with winxp sp2 i have a 160gb hdd wid 2 partitions one with xp installed and d other contains my data.few days ago my com got infected with heur trjan none of the av coukd remove it so i formatted and reinstalled xp.but 2 my surprise wen i tried 2 install d softwares from my dta partition my system caught d virus again.none of av are able 2 detect d trojan which i believe has embedded itself wid my software insatller in my data parition asice my data is 2 imo 2 be deleted so pls sugest a way 2 remove it completely.i have formatted and reinstalled xp at leat 20 times so pllllllllls hellllllllllp!!!!!!!!!!!!!!
sagnik_bose is offline
Old 06-07-2009, 09:25 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: Heur Trojan
You can remove the virus using this software. Or you can check using Trojan Remover or doing a 8-X Kill with Noob Killer
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 07-07-2009, 01:59 PM   #3 (permalink)
We are not blind you know!! To get advice just post in normal fonts!
hell_storm2006 is offline
Old 07-07-2009, 03:19 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
i was too facing it, its very bad virus i had to loose all the files frm my PC and format it completly
VarDOS is offline
Old 08-07-2009, 11:21 AM   #5 (permalink)
does it affect softwares only?are my pic and video files safe from dis trojan?isn't dere ne way 2 disinfect my affected files?
