Old 06-07-2009, 12:23 AM   #1 (permalink)
Question CRC errors on rar archive files.
Hi friends.
I'm new to this digit forum.
The problem with my PC is whenever i'm downloading some files which are in rar format, after download it never extracts properly showing crc errrors. If i force recheck that files it downloads again and next time it shows same crc error on a random file.
I tried to create a archive file using winrar with a 7 GB folder and later test it and found the same crc errors.
Pls guys help me i'm totally confused.
Thanks on advance to everyone who can share their thoughts with me.
jyotisankar9 is offline
Old 06-07-2009, 12:43 AM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: CRC errors on rar archive files.
Check this page: http://labtu.blogspot.com/2009/04/fi...rc-failed.html
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 06-07-2009, 01:00 AM   #3 (permalink)
Thanks for your post. But whenever i'm extracting a disc image loke any game dvd images it is giving me installation errors after extracing.
Old 06-07-2009, 06:53 AM   #4 (permalink)
Amir.php's Avatar
are you using windows vista or windows seven?
http://amirphp.wordpress.com
Amir.php is offline
Old 06-07-2009, 09:33 AM   #5 (permalink)
I tried both Vista and XP
Old 06-07-2009, 10:03 AM   #6 (permalink)
Call me D_J!
Hmm... there may be some problem with RAM while extracting which gives you continuous extracting errors. Install memtest and a test the memory for about 20 mins. If it finds any error it will report.
You can also try extracting using Universal Extractor and UnRAR .
Using UnRAR you can "force extract" the file. install UnRAR in your WinRAR folder. Go to the WinRAR folder through using command line and then use the following command.
Syntax:
unrar x c:\<Destination of your file name> /kb /v c:\<extracting destination>
Hope this helps.
Old 06-07-2009, 11:39 AM   #7 (permalink)
The Boy Who Lived
hjpotter92's Avatar
it may also happen if the download is corrupt, you use some download manager, I assume. moreover, it may also be fault with your winRAR version
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline
