Old 05-07-2009, 12:00 PM   #1 (permalink)
Default Ethernet Hard Disk
Hi,
I have a segate 500 GB external HDD
its only interface is USB
I want to connect this HDD with my wireless router
so that i can share the data with my LT wirelessly
since the router's ethernet interface doesn't allow a USB conn
what the the options where i can connect this ext HDD to router
i searched for usb to ethernet converter(adaptor)
but i am not sure for its practical use
If anyone has used any method to do this please share
it will be completely different senario if i had to use a specfic ethernet HDD
which i am sure a NAS(quite costly)
thanks
razial is offline
Old 05-07-2009, 02:17 PM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Re: Ethernet Hard Disk
I don't think you can just buy a converter and you are through... there are other features needed to make it functional ... for eg. how would your modem know what data is present on which sectors of the HDD.. (-> How can the simple modem + a simple HDD perform functions of an OS ?? )
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
