Old 26-06-2005, 11:27 PM   #1 (permalink)
Default Tunneling Proxy !!!!!!!!!!
Guys, Please tell me any good tunneling software and also how to configure it. I want it to bypass my proxy servers.
freezer is offline
Old 27-06-2005, 06:26 PM   #2 (permalink)
alib_i's Avatar
HTTP - Tunnel
www.http-tunnel.com
Desproxy - Command Prompt tunneling software
http://sourceforge.net/projects/desproxy
Your Freedom
http://www.your-freedom.net/
Hopster
http://www.hopster.com/
I reccomend http-tunnel
alibi
-Metallica
alib_i is offline
Old 20-08-2005, 11:20 PM   #3 (permalink)
Default what is tunnelling?
What is tunneling? Can u please say me why it is used for..
ranjithbajpe is offline
Old 21-08-2005, 12:40 AM   #4 (permalink)
A technology that enables one network to send its data via another network's connections. Tunneling works by encapsulating a network protocol within packets carried by the second network. For example, Microsoft's PPTP technology enables organizations to use the Internet to transmit data across a virtual private network (VPN). It does this by embedding its own network protocol within the TCP/IP packets carried by the Internet.
www.angelfire.com/anime3/internet/network.htm
A method by which packets are encapsulated within a protocol and a header is attached that is understood by the transporting network's routers and switches. "Tunneling" allows files to travel through the Internet as if they were traveling through a private secured network.
www2.hawaii.edu/~dflynn/VPNs/vpnglossary.htm
To handle yourself, use your head; to handle others, use your heart.
sensationalboy is offline
