Old 02-07-2009, 10:03 AM   #1 (permalink)
naughty boy :) :)
mahesh's Avatar
Default Is it wise to upgrade my pc now ?
My current pc config is in my siggy. i have a budget of max 15k. What the components i need to upgrade? i use this pc for gaming as well as for downloading (min 12 hrs in mon - fri and 24 hrs in sat & sun). I usually play fifa 2009, COD 4 , Burn Out Paradise. Plz suggest me the components. Or shall i wait for 2-3 months? Please advise.
PS: I don't intend to overclock.
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 02-07-2009, 10:29 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Is it wise to upgrade my pc now ?
X2 250: 4k-4.5k
Gigabyte 780G based board: 4.5k
Palit HD4850 : 6.5k-7k
This should be enough.
desiibond is offline
Old 02-07-2009, 10:34 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
try to increase budget and get Phenom II X2 550. This is AM3 processor and upgrading mobo after a year or two will be painless as AM2+ processors won't work on AM3 board.
There is one more way.
Give me the exact model number of your board. If it is Socket AM2 or AM2+, AM3 processor will work on it. In that case, Just upgrade processor to Phenom II X2 550 and GPU to GTX260 (total 15k). When DDR3 goes dead cheap and AM3 boards available inside 5k happens, upgrade mobo and RAM.
Old 02-07-2009, 10:49 AM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Phenom II X2 550
790G mobo
ATI HD4850
Somewhat over ur budget but if u wanna upgrade, then upgrade to this. Else u can also upgrade just GPU for now.
Blogging at:
Technostarry
saqib_khan is offline
Old 02-07-2009, 10:54 AM   #5 (permalink)
naughty boy :) :)
mahesh's Avatar
^^^ thanx. I really dont know the exact model number of the board !!!
I think that all the components u mentioned will take more power during idle time??? wat to do?
mahesh is offline
Old 02-07-2009, 11:17 AM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
Here is the power consumption chart of this processor compared to some other processors. I think it consumes less power compared to other processors, check out urself.
BTW, again saying, urs is a nice rig, u can also just upgrade the GPU now and can upgrade processor and mobo later.
Blogging at:
Technostarry
Old 02-07-2009, 11:20 AM   #7 (permalink)
naughty boy :) :)
mahesh's Avatar
^^^ thanx dude. I will also think abt ur advice
mahesh is offline
