Old 30-06-2009, 10:12 PM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default SNR
SNR (Downstream) 20.5 dB
SNR (Upstream) 19.0 dB
Line Attentuation(Downstream) 28.0 dB
Line Attentuation(Upstream) 13.0 dB
this is my result...please do comment on its improvements and all
JohnephSi is offline
Old 30-06-2009, 10:18 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: SNR
Please update this poor soul. Wat is dat??
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 30-06-2009, 11:09 PM   #3 (permalink)
JohnephSi's Avatar
Default Re: SNR
it is regrdng bsnl broadband
Old 01-07-2009, 12:08 AM   #4 (permalink)
Default Re: SNR
SNR stands for "Signal-to-Noise Ratio". It is used to evaluate the quality of electrical signals, not only with internet connections, but also with many applications in electronics such as audio, video, etc.
Technically speaking, it is the ratio of the desired signal to unwanted electrical noise, expressed in decibels (db). Mathematically, it is
SNR = 10*log (signal power/noise power) or 20*log (signal voltage/noise voltage).
The higher the SNR figure, the better.
Attenuation is the extent to which the strength of the desired signal is reduced, compared to a standard level. So the lower the attenuation, the better.
pimpom is offline
