Old 30-06-2009, 01:33 PM   #1 (permalink)
Default Suggest Upgrading RAM ?
I recently purchased Compaq Core2Duo (CQ40)laptop with 2 GB Ram. I want to upgrade ram to 4 GB , plz advice would it give noticeable speed difference.
good day
Amit
amit_stg is offline
Old 30-06-2009, 01:51 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Suggest Upgrading RAM ?
well, if the OS u are using is 32bit, then i will recognise jus 3GB of System RAM inspite u u installing 4GB or above..
to get full performance of ur 4GB RAM, install 64bit os, be it even XP or Vista..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
