Old 26-06-2005, 01:22 PM   #1 (permalink)
Default New system for 45-50 grand MAX
hii guyz
i am looking for a system for 45-50 grand MAX.50 grand at MAX cant spend for then that.
basically i need a 17''CRT monitor.
decent gpu.
160GB sata or may be 120 will do.
dvd-rom,dc-rw.
so please suggest above things with price as well as processor,motherboard, and other things please with price.
THANX IN ADVANCE
diabolic_saint is offline
Old 26-06-2005, 01:26 PM   #2 (permalink)
Haven't you bought already?
http://www.thinkdigit.com/forum/view...122&highlight=
Delpiero is offline
Old 26-06-2005, 06:15 PM   #3 (permalink)
yea i have but that one my brother is taking with me 2 delhi so some how i have convienced my father to get me one and he has agreed and will give me some where around 45-50k max thats why troubling you people again .i have bought one AMD u this time i prefer a intel platform but wat do u guyz say AMD OR INTEL???plz tell me soon with config and price..thanks.
Old 26-06-2005, 07:10 PM   #4 (permalink)
GAMING PC
Amd 3000 64bit winchester
Asus A8N-E or something that is better fo you
abt 15-16k
2 X 512mb orignal hynix d43(beware of fake hynix) ddr 400
ab 6k
160gb seagate sata ncq,consider sata II if you can afford it and find it
4150
128mb geforce 6600gt pci-e gigabyte,leadtek,xfx etc
abt 10k and up,rough price
Cabinet + Zebronics or better 400-500(450 watts may be better than 500 from this),check on high +12va line and other lines
abt 1.5-2k and higher
CD-RW
and dvd rom separte abt 2.7k and up as rough price
if you can afford dvd -rw ,then take it
dvd rw + combo =abt 6.5k
fdd sony or whichever if ok
i have sony
abt 300
17"true flat samsung 793mb
7100
acer having 1600*1200 res may be for abt 6500
don't rely only on digit and check from other sources and from abroad sites as well
microsoft internet keyboard + mouse pad + microsfot basic optical mouse,all in about 1 grand
if you can find microsoft ms optical wheel mouse then take it , may have better censor or something
may be abt 400 bucks more
also,basic mouse may be small
but i have it and might take this mouse in this budget if reuired to have just a single mouse or such choice
or consider geforce 6800gt leadtek + amd 2800(s754) + asus k8n,
cpu + mb + ram =abt 27k
cpu+mb=abt 10k
cpu=abt 5k
akshayt is offline
Old 26-06-2005, 07:18 PM   #5 (permalink)
Aniruddh's Avatar
@diabolic saint
well man as u already hav one AMD dat does mean dat u cant buy one more.how bout ur pc is it ok u satisfied wid it or not?well here goes the intel config:-
1:-3.0GHZ LGA-775-8.5K
2:-ASUS P5-GD1(915)-7.5k
3:-17'' samsung MB2-8K
4:-2*256 400mhz RAM corsair/kingston-3.4k
5:-160GB Sata Seagate HDD-4k
6:-GPU 6600 non gt-6k
7:-Numeric VA600 UPS-2k
8:-Power safe SMPS-1.6k
9VD-ROM,CD-RW Sony/Liteon-3k
10:-Microsoft Keyboard & opti mouse-1.5k
11:-Cabinet which ever u like-1.2k
Speakers i dun hav much idea i m sure others will tellu....
well dis config will b in ur budget will come inside 50k...
Aniruddh is offline
Old 26-06-2005, 07:27 PM   #6 (permalink)
Aniruddh's Avatar
@akshayt
well pal no doubt its a gud config da one u suggested but did u calculate da price of dat config its more then 50 grand and he has already told dat he juz cant afford a single penny more then dat...
Aniruddh is offline
Old 27-06-2005, 02:19 AM   #7 (permalink)
The Hardware Labs
mohit's Avatar
@diabolic_saint
the config aniruddh has sugested is quite good but if u r a gamer then go for a leadtek 6600gt extreme 128 mb .. cut out on the following ,
go for 80 gb instead of 160 gb sata
go for logitech kb/optical mouse
speakers
save the money for buying a 6600gt as it will allow u good gaming (if dats ur purpose). else the confg suggested by aniruddh is quite good.
mohit is offline
Old 27-06-2005, 02:25 PM   #8 (permalink)
go for AMD 64 platform if u r into gaming.But, as ur budjet is 50K, save on fancy things like speakers for a more powerful GPU, and later whn u have the cash, u can add spkrs or Cam or a dvd writer.
Rajeev V Nair
premrajeev is offline
