25-06-2009, 05:36 PM
"Aal Izz Well"
Zone Alarm : Open blocked port??
I am a Windows XP user and I use ZoneAlarm Free 8.0.298.0..Download from here
Note:- I m using ZoneAlarm Free 8.0.298.0 Not Pro version....
Now the problem:-
Case 1:-
I checked my port 27960 UDP using PFPortCheck Program..(Zone Alarm ON).
^^ It shows your port is blokced...
Case 2:-
I checked my port 27960 UDP using PFPortCheck Program..(Zone Alarm OFF..shutted down).
^^ It shows your port is Open...
WTF! ZoneAlarm blocking my port 27960...HOW TO OPEN IT...?
Note:- Plz dont say ZoneAlarm sucks..use macafee blah blah stuff! stay ontopic and DONT MAKE THIS THREAD A FIREWALL WAR THREAD!
http://twitter.com/krazzywarrior
25-06-2009, 07:28 PM
Tribal Boy
Re: Zone Alarm : Open blocked port??
25-06-2009, 09:36 PM
"Aal Izz Well"
hmm... seems useful wait checking up and then i'll reply...
25-06-2009, 10:42 PM
Originally Posted by Krazzy Warrior
I am a Windows XP user and I use ZoneAlarm 7.0.473..
Now the problem:-
Case 1:-
Case 2:-
You don't need to worry about it as we are still able to connect to your servers so the port is OPEN.....
even if Zone Alarm says that it is closed.
BTW you could try www.portforward.com
25-06-2009, 10:43 PM
Just quit Zone Alarm while hosting or you could try to get help elsewhere.
25-06-2009, 10:52 PM
Call me D_J!
You can do one thing... Uninstall ZA and reinstall it. Now whenever the prompt comes for allowing the specific port to be opened... select Allow and tick "Remember my Answer".
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
26-06-2009, 08:50 AM
"Aal Izz Well"
I shut down ZoneAlarm while hosting so u r able to connect! but i dont want to shut it! i mean i want zonealarm to be on while hosting!This is the reason i m asking for solving this problem....
It always ask for allowing or disallowing a program and NOT for port!
@din
wait checking it up! a problem wait i will write it here when i get time!
26-06-2009, 08:57 AM
@din
Try
http://www.bleepingcomputer.com/tuto...torial128.html
http://www.ehow.com/how_2262012_open...alarm-pro.html
GOOGLE your problem first!
26-06-2009, 08:59 AM
"Aal Izz Well"
wait i check and i will too check @ portforward.com
Edit#1:-
And tutorial provided by u guys(din,aspire) is based on PRO version...And i cant too find option as written in Pro version tutorial in my free version ZA...
26-06-2009, 09:30 AM
"Aal Izz Well"
@Aspire
http://www.portforward.com/english/r...2T/default.htm
I try to port forward from here ^^^
See the first line of the page:-
To setup port forwarding on this router your computer needs to have a STATIC IP ADDRESS
WTF! i dont want to have a static ip address..i have dynamic ip address...i want to open port keeping ip address dynamic..help
Edit#1:-
Originally Posted by din
Tutorial provided by u is based on PRO version(I am using ZA free version see the 1st post)...And i cant too find option as written in Pro version tutorial in my free version ZA...
26-06-2009, 09:31 AM
You need to enter your modem Ip like mine is 192.168.1.34
Your modem has a IP u need to use it.......
26-06-2009, 10:02 AM
"Aal Izz Well"
kk! i did! nothing helped!
Crazy u didnt get my question! There is nothing wrong from Router end as when ZoneAlarm off, port is open...There is problem from ZoneAlarm end as when ZoneAlarm on, port is closed! So, the thing is that my router configuration is right but that of ZoneAlarms is wrong! <<-- Clear this thing.
btw Port Forwarding = Opening Port ???????
26-06-2009, 11:25 AM
YES
26-06-2009, 11:35 AM
"Aal Izz Well"
^kk thx!
Anyone HELP!!!!!
26-06-2009, 11:37 AM
^kk thx!
Anyone HELP!!!!!
To forward ports in ZA go to Firewall>Internet Zone Security>Custom then click Allow incoming UDP ports, type port you want to forward and Apply. Repeat the same for Allow Outgoing UDP ports. Do the same for TCP ports.
26-06-2009, 11:38 AM
You don't have to buy anything.
In the free Zone Alarm firewall, go to Overview, Preferences, and click on enable proxy server. Type in your port number, and you're good to go. It seems like it can only do one port at a time, however.
But Windows firewall can do more, and adds UDP and TCP options. Go to Control Panel, Windows Firewall, Security Center, Exceptions, and Add Port. To be even safer, click on go to "change scope" and add the IP addresses of those you wish to play with.
There is no reason anyone should have to pay any money for a firewall to protect them while playing games (unless you want the new fangled thing that detects which game you're playing and inputs the ports for you).
Sry forgot to Edit, so no need to give lecture on Editing Posts.
Source: http://icrontic.com/forum/archive/index.php/t-3304.html
26-06-2009, 12:15 PM
"Aal Izz Well"
In the free Zone Alarm firewall, go to Overview, Preferences, and click on enable proxy server. Type in your port number, and you're good to go. It seems like it can only do one port at a time.
hmmm tried didn't helped "Your Port in NOT OPEN"
Help
26-06-2009, 12:42 PM
26-06-2009, 02:30 PM
#19 (permalink)
"Aal Izz Well"
To forward ports in ZA go to Firewall>Internet Zone Security>Custom then click Allow incoming UDP ports,type port you want to forward and Apply. Repeat the same for Allow Outgoing UDP ports. Do the same for TCP ports.
Where is the Custom button????
Click to ZOOM!
27-06-2009, 07:46 AM
#20 (permalink)
Click to ZOOM!
You f0ol, click on Advanced!!!!!!
27-06-2009, 08:20 AM
#21 (permalink)
"Aal Izz Well"
huh i checked Advanced at that time and theres nothing for opening port!
Saying me fool lol :-P
Gouchu check this advance menu..
27-06-2009, 08:30 AM
#22 (permalink)
Uncheck 1394 you f0ol! and host via port 1394!
27-06-2009, 08:37 AM
#23 (permalink)
"Aal Izz Well"
^^ i know this! i was just asking for opening other ports! i mean sometime i too need to open 80 port or blah blah! leave i think its not possible in ZA! really ZA sucks  I searched all over net and think opening specific port is only possible in pro version...
27-06-2009, 08:40 AM
#24 (permalink)
What was i telling you all the time??
Uninstall ZA and use Windows Firewall but you just wouldn't listen........
happy now?
27-06-2009, 08:46 AM
#25 (permalink)
Call me D_J!
I was using the pro version but it's a memory hog and it On-Access Scanning makes things worse. I am using CIS now and I am really happy with it.
27-06-2009, 08:56 AM
#26 (permalink)
"Aal Izz Well"
Nah i will keep ZA installed and wont install Windows Firewall it sucks even more
27-06-2009, 09:51 AM
#27 (permalink)
won't install??
It comes preloaded!
27-06-2009, 09:56 AM
#28 (permalink)
"Aal Izz Well"
^Lol! i know its preloaded but i have off it!
Search this Thread |
