LinkBack (1) Thread Tools Search this Thread Display Modes
Old 25-06-2009, 12:49 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Difference between 1080i and 1080p
What is the difference between 1080i and 1080p?
thetechfreak is offline
Old 25-06-2009, 12:51 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Difference between 1080i and 1080p
http://hometheater.about.com/od/tele...80ivs1080p.htm
desiibond is offline
Old 25-06-2009, 01:57 PM   #3 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
1080i means there will be 1080 vertical lines which are interlanced. Interlance is a technology which will allow the devices to display improved picture quality with out demanding high bandwidth.
1080p means there will be 1080 vertical lines which displyed in progressive mode. So, this can be considered as FullHD. While 1080i in only HD not FullHD.
Another differnce to note is that 1080i videos can be played @ maximum frames of 30fps. While 1080p videos can be played on 60fps.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is online now
Old 26-06-2009, 11:59 AM   #4 (permalink)
Thanks
Old 01-07-2009, 01:20 PM   #5 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
hey thanx alot for this info..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 01-07-2009, 01:30 PM   #6 (permalink)
my pleasure, ashu.
Old 03-07-2009, 10:29 PM   #7 (permalink)
tHe nEw gEEk......ITian
pr.itdude's Avatar
so which one is better......?? 1080p.......??
pr.itdude is offline
Old 03-07-2009, 10:51 PM   #8 (permalink)
Of course.
SunnyChahal is offline
Old 03-07-2009, 10:54 PM   #9 (permalink)
RPG FTW!!!
Techn0crat's Avatar
If your PC can play them without any issue and If you have HDD with high storeage capacity,1080p are good.
Techn0crat is offline
Old 03-07-2009, 11:00 PM   #10 (permalink)
damnbadman666
damngoodman999's Avatar
Interlaced !!
Its ok , but not all the HD monitors 1080p can play @ 60FPS with the BLUray Video optimized to 60FPS ,
As i saw many Bluray videos in INDIA are not optimized to 60FPS , hollywood movies does the job
http://www.thebestplasmatv.com/guides/1080p-vs-1080i/
damngoodman999 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/118667-difference-between-1080i-1080p.html
Crysis 2 PS3 is Sub-HD | N4G This thread Refback 26-02-2011 03:30 AM
