Old 26-06-2005, 08:55 AM   #1 (permalink)
Default Pros of SMPS
I just needed to convince my father that a 400W SMPS is necessary for computer .SO that he will get me one of Antec since he is going to Mumbai for a conferrence .So please anybody write about PSU.
IN HOUSE GEEK!!!!!!!!!!!!!!!!!!!!
chirayu garg is offline
Old 26-06-2005, 12:12 PM   #2 (permalink)
The Lord of Death
Yamaraj's Avatar
Given the power requirements of any fairly modern and powerful machine,
a good branded PSU becomes a necessity if you want to make sure the
computer won't fall prey to technical failures.
For any P4/AMD64 machine, without SLi, at least 400W or 450W PSU is
recommended. While for an SLi setup, one should opt for at least 550W
power supply from good brands such as Antec, Enermax, Tagan, or
Thermaltake. One thing to specifically look out for is the +12V rail total
output. It should be capable of providing at least 20A or better. My
Antec TrueBlue 480W has a total of 28A on +12V rails.
More, if you have the latest PCI-X motherboard and graphics cards, you
should better be looking for a dual +12V power supply with a 24-pin main
connector, as well as 6-pin PCI-Express connector(s). This new config for
the PSU is known as the ATX 2.0 standard.
So, go convince your father to purchase a decent, probably Antec, PSU for
your machine. He wouldn't like to spend money on new components if a
white-box PSU burns your computer inside out.
- Yamaraj
Yamaraj is offline
Old 26-06-2005, 06:36 PM   #3 (permalink)
Yamaraj , I am going for antec smart power 400W is it good.
Old 26-06-2005, 07:05 PM   #4 (permalink)
Aniruddh's Avatar
@chirayu garg
sorry u asked yamaraj but still i m givin u suggestion well its gud no doubt bout dat one go for it...
Aniruddh is offline
Old 26-06-2005, 10:03 PM   #5 (permalink)
Originally Posted by Aniruddh
@chirayu garg
That's fine dude.
