Originally Posted by Kl@w-24
Why do you need to convert them manually? Most burning apps will convert the videos to the VCD format if you select Video CD as the compilation type.
+1. But in that case the file size would increase to some GBs.
Try ConvertxToDVD software. It would keep the file size quite same. Means it won;t increase the size if YOU don't want
and would convert them to DVD format.
You can directly burn DVD from the s/w or u can burn as image.
