Old 26-06-2005, 07:55 AM   #1 (permalink)
q3_abhi's Avatar
Default I have a BIOS updating Solution.
Guyz,i can see every now n then ,the problems of updating BIOS getting on. I have created a .doc file of "How to update ur BIOS" which was there in one of the DIGIT issue. So what do u think Should i paste that solution here so that everybody can see it??? Or anything else???? Should i continue doing this???
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 26-06-2005, 09:07 AM   #2 (permalink)
vishal_bhatia87
Posts: n/a
Yes, upload it. So, it may help the beginners.
Old 26-06-2005, 07:33 PM   #3 (permalink)
I am waiting for your .doc file.
It will a great help
Techmastro is offline
Old 26-06-2005, 09:35 PM   #4 (permalink)
q3_abhi's Avatar
Doing that flash thing
Note: Flashing your BIOS can be fatal for your motherboard if there is a power failure or surge during the flashing process. If your system is working fine and you don’t find any problems with your motherboard, do not upgrade your BIOS. If you decide to do so anyway, make sure to get some assistance from an engineer or a person well versed in computer hardware.
The process explained here is applicable to popular Award BIOS (applicable to some more).
Before you begin make sure you have a bootable floppy.
STEP 1
Identity your motherboard and the current BIOS version. Press the PAUSE key while your system boots up and note down the signature of your BIOS. The name of your BIOS manufacturer shows up at the top left corner of the screen while your system does a part of the string, denotes the motherboard manufacturer, in this case, DFI (Diamond Flower).
If your motherboard uses an Award BIOS, you can check for the manufacturer at
www.abios.com/award.html . If it uses an AMI BIOS, check www.bios.com/ami.html
STEP 2
Depending on the type of your BIOS, download the latest flash utility and the necessary update file from your motherboard manufacturer’s site to Floppy Disk. Unzip the files. There should be three files in all: an .exe file, a .bin file (BIOS update) and a .txt file.
Copy the .exe and .bin files to the bootable floppy disk.
STEP 3
Boot your PC using a bootable floppy. See to it that no memory management programs or emulators such as emm386.exe are running, as this might interrupt the update process.
STEP 4
On running the flash utility, type the executable filename with the parameter as follows:
A:\> [executable file] [bin file]
You can type [executable file] / ? to seek help on using the file.
STEP 5
Most flash updating utilities have an option to backup your old BIOS settings. Make sure that you backup the current BIOS to a file by using the same utility.
STEP 6
Check the path of the .bin file and press [Enter] to proceed. You’ll be asked for a confirmation. Press [y] to continue. The software will automatically update your BIOS. During this period there should be no power surges or electrical disturbances, else your BIOS can get corrupted and you have to replace it (if the BIOS is socketed) or buy a new motherboard (if it’s hardwired).
STEP 7
Exit the flash updating utility, reboot the PC and enter the BIOS settings by pressing [Del] while your system boots. Load the BIOS defaults by pressing [F6] or [F7], as required. Now when you reboot your PC, your BIOS ID at the bottom left corner of the screen should show the new date (the date on which you flashed your BIOS.)
You’re done. Now your PC will run smooth and steady with the newer instructions written into your BIOS. Hardware compatibility issues and bugs, if any, will also get resolved when you flash the BIOS.
q3_abhi is offline
Old 28-06-2005, 09:53 PM   #5 (permalink)
q3_abhi's Avatar
Is this solution really helpful?? Please tell me!!
q3_abhi is offline
Old 30-06-2005, 11:00 PM   #6 (permalink)
q3_abhi's Avatar
Please tell frankly, is this solution very lengthy n very boring,so that i may delete it??? Reply to it ,be frank.
q3_abhi is offline
Old 01-07-2005, 01:03 PM   #7 (permalink)
Default its gud
this is gud
infact this is the only solution for Bios Updating
johny
PAIN IS THE WAY TO FEEL LIVING. SO ENJOY THE PAIN & FEEL LIFE
johny_4board is offline
Old 01-07-2005, 02:00 PM   #8 (permalink)
expertno.1's Avatar
hmm
well this is not boring at all
a computer learner will appreciate the work of your .doc file
and i think bios updating is very very risky
expertno.1 is offline
Old 02-07-2005, 10:50 PM   #9 (permalink)
q3_abhi's Avatar
Thank u for ur replies
q3_abhi is offline
Old 13-11-2005, 12:50 PM   #10 (permalink)
The Incredible's Avatar
i'm having phoenix award bios.
mobo manf is biostar
ink to site is www.biostar.com
mobo name M7VKQ
i used to update my bios using everest but since i have switched to win xp, the link which everest gives doesnt works.
The Incredible is offline
