Old 20-06-2009, 01:56 AM   #1 (permalink)
GOD
vaibhav_jain's Avatar
Question Enquiry about RAM Compatibility!!!!!!!!!!!
i have a system whose configuration is following-:
Intel pentium D 3.0 GHz, Intel original motherboard 946, Transcend RAM DDR2 667 Mhz 512MB clkspd=5, Kingston Ram DDR2 667 Mhz 1 GB clkspd=5.
I want upgrade my memory, so i want to purchase a 2 GB DDR2 RAM Stick 667MHz clkspd=5. But now it is not available in the market. but one of the shopkeeper tells me to purchase 800 MHz it will run on my motherboard.
Can this be possible? Does my above said RAM works fine with my new purchased 800 MHz RAM?
Please suggest me the good solution?
Vaibhav Jain
vaibhav_jain is offline
Old 20-06-2009, 02:42 AM   #2 (permalink)
Default Re: Enquiry about RAM Compatibility!!!!!!!!!!!
Most 946 m/b support 800 Mhz ddr 2 ram by default. Anyhow, Ddr 800 hz ram are backward compatible with ddr 667 , so it should work even at 667 speed. Just get a kingston 2 gb stick - around 1200 rs. Avoid simtronics etc.
jeetu is offline
Old 20-06-2009, 10:40 AM   #3 (permalink)
GOD
Exclamation Re: Enquiry about RAM Compatibility!!!!!!!!!!!
My motherboard is 946GZIS and accordint to its specification it only supports memory upto 667 MHz.
Vaibhav Jain
Old 20-06-2009, 12:08 PM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
ya its limit 667 , but some board takes 800 as 667 , in case only it works not sure better make a sample ram in to your mobo
damngoodman999 is offline
Old 20-06-2009, 12:21 PM   #5 (permalink)
paroh's Avatar
99.9% chances of, It will work. Or u can ask ur vendor to get it replaced if it does not work
As i can confirm u that my board also supports DDr2 667mhz max. and i am using 2 667 1GB each and one 553mhz ram with no problem
see this as it shows that 800mhz can run at 800mhz,667mhz and 533mhz
http://cgi.ebay.in/2GB-DDR2-800MHZ-PC6400-LAPTOP-RAM-TRANSCEND-667-533-400_W0QQitemZ400056108524QQcmdZViewItemQQimsxZ20090616?IMSfp=TL090616209001r2611
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
