Old 25-06-2005, 02:26 PM   #1 (permalink)
expertno.1's Avatar
Default fastest proxy servers in india
can anyone give me the lsit of free proxy servers of india including the address and port
but remeber the fastest ones
please
[/code]
expertno.1 is offline
Old 25-06-2005, 07:38 PM   #2 (permalink)
QA Juggler
saROMan's Avatar
IP Port Type Country
61.11.8.195 3128 transparent India
210.212.166.4 3128 transparent India
203.109.98.190 8000 transparent India
202.144.83.234 3128 transparent India
203.197.239.218 8080 high anonymity India
203.101.97.22 3128 transparent India
203.115.71.10 80 transparent India
203.196.149.97 3128 transparent India
203.101.67.28 80 transparent India
218.248.1.13 8080 anonymous India
210.212.79.14 3128 transparent India
220.227.153.146 8080 high anonymity India
210.212.165.130 8080 anonymous India
61.11.25.2 8080 anonymous India
203.199.92.158 80 anonymous India
203.197.196.178 80 anonymous India
bud...cudnt get the time to check them.......
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 25-06-2005, 07:40 PM   #3 (permalink)
bharat_r's Avatar
if u hadn't checked how can u find the fastest servers.
Someone check & tell the fast ones.
bharat_r is offline
Old 25-06-2005, 07:41 PM   #4 (permalink)
expertno.1's Avatar
well thanks for this but about speedy proxy servers ?
which one is the fastest among these ?
Old 25-06-2005, 07:47 PM   #5 (permalink)
QA Juggler
saROMan's Avatar
Well bro...i dont use free proxy's ..and use some high End softs..so give me a Soft name or method to chk them..and i will do that for u..
saROMan is offline
Old 25-06-2005, 07:53 PM   #6 (permalink)
expertno.1's Avatar
what high end softs do u use ??????????????
Old 25-06-2005, 08:13 PM   #7 (permalink)
QA Juggler
saROMan's Avatar
well GhostSurf Pro 2005/Complete Anonymus Web Surfing(COWS)/ AllegroSurf 7.0 etc ..but let me Warn you none of them is Free
saROMan is offline
Old 25-06-2005, 08:38 PM   #8 (permalink)
Biplav's Avatar
i use anonymous software form zilla anonymous surfer.
gices me good speeds but i use it only when i need it, not all the time i am on the net. coz it gets slow that ways(just like any other anonymous software)but it is faster than others though.
try it out here.
www.zillasoft.ws
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 26-06-2005, 10:58 AM   #9 (permalink)
Rebooting
Choto Cheeta's Avatar
btw saROMan the link u have given http://www.softforall.com/Internet/O...ng06110033.htm doesnt have any donwlaod button.... at list i cant locate one...
Choto Cheeta is offline
Old 26-06-2005, 12:32 PM   #10 (permalink)
QA Juggler
saROMan's Avatar
strange there is a Download button right under the Description..any ways Here is the Direct link to Download
saROMan is offline
Old 26-06-2005, 03:38 PM   #11 (permalink)
vishal_bhatia87
Posts: n/a
try it out here.
www.zillasoft.ws
Dude it is free or commercial?
Old 26-06-2005, 08:40 PM   #12 (permalink)
Biplav's Avatar
i think its free coz i have it downloaded from over a month now.
i dont use it much, as i have already said use it only and only when u need it.(i have to hide my identity very few a times)
Biplav is offline
Old 27-06-2005, 02:14 PM   #13 (permalink)
expertno.1's Avatar
hey hey no one has told about the fastest proxy servers
anyone ??
Old 27-06-2005, 02:20 PM   #14 (permalink)
Just Do It
Charley's Avatar
These ones above dont work ... Why is that so ??
Charley is offline
Old 27-06-2005, 02:26 PM   #15 (permalink)
QA Juggler
saROMan's Avatar
well bro try this software
ProxyChecker 3.27 Freeware
ProxyChecker allows you to test lists of proxies. This program allows you to check just one proxy sever, or several proxy servers simultaneously. With ProxyChecker you can check for anonymous proxies, recheck a proxy, save proxies to a file, check for duplicated proxies and remove them, use multithreading to check lists of proxies, and more.In order to use ProxyChecker you must download registration key for FREE. You can't redistribute this key or link to this key! But you may link to home page.
Proxy Grabber 2.0 Shareware
Full Description:
Main Proxy Grabber features: Scanning/checking of SOCKS4, SOCKS5, HTTP, FTP and TELNET proxy servers SMTP relays scanning/checking Very fast TCP port scanner Server name definition Server response time definition Scheduler Original scanning technology, that allows saying 'Proxy Grabber is the fastest proxy scanner' Random IP generator User-friendly interface What differs our program from analogs ? Almost all proxy scanners are based on so called 'multi-threading' scanning technology that applies some restriction on they way those programs and operating system work. All proxy scanners we have tested could not work with more than 100-200 ip addresses simultaneously (100-200 threads!!!), thus operating system productivity dropped almost to zero, and scanning time was increased. Proxy Grabber does not use 'multi-threading' scanning technology. Proxy Grabber can simultaneously check unlimited quantity of ip addresses for the presence of proxy servers or opened ports, almost not loading the operating system. Proxy Grabber is written on 100% the assembler language that also speeds up scanning, and reduces program size.
saROMan is offline
Old 27-06-2005, 02:32 PM   #16 (permalink)
Just Do It
Charley's Avatar
This is the one I tried .... No response... Is the proxy blacklisted ??
Charley is offline
Old 27-06-2005, 08:08 PM   #17 (permalink)
expertno.1's Avatar
well well well
saroman posted some of the proxy servers
but no one has replied which one is the fastest among these
can anyone tell which one is the fastest..i dont want to dwonlaod any 3 rd party software
i just want to know which one is the fastest among the posts of saroman
anyone please tell me imediately
Old 27-06-2005, 08:55 PM   #18 (permalink)
Just Do It
Charley's Avatar
Originally Posted by expertno.1
well well well
Well, dont be lazy, help urself. He or anyones not gonna try each one and spoon feed you.
Charley is offline
