Hello Friends
Can someone plzz telll me which player to use to play HD movie files on pc ????
I tried VLC, GOM, WMP...... but it dosent play properly, it stucks in between
If you can open the movie in amy of the media players you've mantioned above thn there's probably no problem with your software(the media player, in this case). Secondly, i would suggest u check ur config if it is capable of playing HD media or not. A better idea would be to post it here so tht we can help you!
