I guess nobody else would have this problem!!
The slide show feature of Windows XP Pro SP2 has stopped working in my system. If I go to a folder full of JPG files, in the common tasks pane (left side) the "View as slide show" link appears, but when clicking on it, nothing happens! Moreover, when I right-click any JPG file I don't find the "Preview" command in the context menu! (The one that is supposed to load Windows Picture and Fax Viewer.
This is also applicable to all other types of picture files supported by Windows Pic n Fax Viewer.
Note: I am an advanced user, so I go into the hidden and core settings of the operating system and modify them to suit me or just to experiment. If slide show and pic-n-fax viewer support needs something that might have been accidentally disabled by me, please tell me.
Thank you.
