Old 09-06-2009, 10:55 PM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default What are the advantages/disadvantages of Port Forwarding ?
What are the advantages/disadvantages of Port Forwarding ? How does it help in increasing the download speed......plz elaborate about this
JohnephSi is offline
Old 10-06-2009, 09:12 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: What are the advantages/disadvantages of Port Forwarding ?
well..
on simple terms..Port Forwarding is a simple method of setting up a dedicated port on ur PC wich will specifically and especially used for Torrent downloads..
Although the port 80 (for http) is always open for internet access, torrent or larger file sharing requires a dedicated port so that the data doesnt conflict with the port 80 (wich as it is, is hell lotta busy with http requests and responses)..
Also, as the port becomes dedicated, d/load speeds do get better (but doesnt increase above a specific limit, set by ur ISP)..
Torrents work on the principle of sharing, its a p2p network so u will d/load sumthing and in return must giv (upload) back or share the data to the community....
if not, then such thing is known as leeching and ;eechers (more precisely, those IP addresses) are banned from the n/w and so eventually u are NOT able to d/load anything..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
