Old 25-06-2005, 01:16 AM   #1 (permalink)
Default 30 GB missing!!!!!
I have a harddisk 160 GB... Westerndigital....... I formated it a month back... It is later that i realised that it is only showing 128GB.... What would be the the reason for this.... What is the the solution for the problem.. Help me out...............
computerwizard is offline
Old 25-06-2005, 01:50 AM   #2 (permalink)
What is the configaration of your system?
What Operating System are you using?
Captain Digit is offline
Old 25-06-2005, 02:28 PM   #3 (permalink)
try using fdisk and is is there some free space
aditya169 is offline
Old 25-06-2005, 03:22 PM   #4 (permalink)
siriusb's Avatar
Ain't that got something do with XP? So I am assumuing u got xp.
If u don't have SP2, install and see. Also, search for 48bit lba support for XP. There's plenty of times this query has been answered.
siriusb is offline
Old 25-06-2005, 03:23 PM   #5 (permalink)
bang bang!
Chirag's Avatar
Same prob. there was with me.
Follow the following steps :-
1) Right click on "My Computers". (A window will appear)
2) Go to Manage. (on left)
3) (on left side) under "Storage option" go to "Disk Management"
4) See the sizes of each drive. If there is somewhere written 32 GB Free Space then create a new drive with that 32 GB.
(My prob. was solved with this)
Tell me if this helped u.
Chirag is offline
Old 26-06-2005, 02:04 AM   #6 (permalink)
thanks for the reply....
No i dont think its the problem with the config bcoz i tried on two computers... But i formated the disk using windows disk management... So the problem isnt sovled even here.... Can any one helpme out..... wait i havnt tried out the "48bit lba support for XP" posted by siriusb that might work........ and hope it does
Old 26-06-2005, 07:43 AM   #7 (permalink)
ammusk's Avatar
Default got 160
i also recently purchased a 160GB
however when i formatted it
it showed me 149 GB
better check with ur vendor
ammusk is offline
Old 26-06-2005, 08:44 AM   #8 (permalink)
bang bang!
Chirag's Avatar
U don't have to format the drive from Disk Management.
Tell me what u see in ur Disk Management Window
Chirag is offline
Old 29-06-2005, 02:23 PM   #9 (permalink)
Fresh Stock Since 2005
If XP, use the Logical Disk Manager under computer management (Start>Run>Compmgmt.msc) and ook for the lost space and create a drive in it...........
Use professional toolz(such as PQMAGIC) for more options (like merging it to curent partitions and such.............)
Hope it helps
http://www.khattam.info
khattam_ is offline
Old 29-06-2005, 03:38 PM   #10 (permalink)
siriusb's Avatar
Now really. This is a documented problem. As pointed out already, it has to do with the 48 bit lba support in xp. Atleast that's what's google saying. Here, take a lo0k:
http://support.microsoft.com/default...en-us%3B303013
http://answers.google.com/answers/threadview?id=6682
http://www.winguides.com/registry/display.php/1115/
siriusb is offline
Old 29-06-2005, 10:25 PM   #11 (permalink)
are u sure u didnt miss any partition during installation.
Insert ur Win XP cd and reboot and go upto the partition see if it shows any free space. I think it should. Make that partion raw by defining its limits.
Reboot without CD go to My Computer it will show u an RAW space format it and thats it.
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 04-07-2005, 01:42 AM   #12 (permalink)
busyanuj's Avatar
Default Re: got 160
it showed me 149 GB
there's no problem with your hard drive, because the hard drive manufacturers make all hard drives according to the capacity in multiples of million units.
where as actually 1 kb = 1024 bytes and 1mb = 1024 kb and so on.
so, a 160 gb hard drive is actually 149.011 gb only in size.
busyanuj is offline
Old 04-07-2005, 05:06 AM   #13 (permalink)
siriusb's Avatar
Default Re: got 160
it showed me 149 GB
160 minus 149.011 ain't 30GB, which is what the OP seems to be missing. How about going to here:
siriusb is offline
Old 04-07-2005, 04:48 PM   #14 (permalink)
busyanuj's Avatar
Default Re: got 160
it showed me 149 GB
if you notice carefully, I had addressed ammusk's query, not computerwizard's query
busyanuj is offline
Old 05-07-2005, 05:54 AM   #15 (permalink)
siriusb's Avatar
Oops, sorry busyanuj, didn't notice that quote.
Oi, computerwizard, did any of the suggestions work?
siriusb is offline
