Old 25-06-2005, 12:26 AM   #1 (permalink)
Default Monitor screen shaking!!
Hi all,
I have got a serious problem with my monitor. Whenever I switch on my monitor, the screen shakes voilently. nothing is seen clear. It keeps on shaking till the welcome screen comes. Its not that the screen becomes stable when the monitor is heated up, it shakes every time it is rebooted on whenever bios comes till the welcome screen. Is my monitor is in its last stages?? Please help.
Thanks
Krish
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 25-06-2005, 12:29 AM   #2 (permalink)
yeah i think so get it checked NOW !!!!
Cheers !!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 25-06-2005, 12:07 PM   #3 (permalink)
expertno.1's Avatar
check this
1) if any magnetic device is near the monitor like fan then remove it
2)remove your mobile from there
3)degauss your monitor
4)increase the Hz frequency of your monitor i.e the dispaly refresh
5)last-option-contatc the technician
expertno.1 is offline
Old 25-06-2005, 07:14 PM   #4 (permalink)
Checked:
1) any magnetic devices - removed
2)mobile - removed
3)degauss your monitor - done
4)increase the Hz frequency of your monitor i.e the dispaly refresh - 85Hz
No Help till now!!!
5)last-option-contact the technician - to be done now
krish is offline
Old 25-06-2005, 07:24 PM   #5 (permalink)
expertno.1's Avatar
then call the technician coz i dont think there are other causes of screen flickering
1)how old is your monitor?
2) does flickering occurs in windwos mode also ?
3) contatc the technician
Old 25-06-2005, 09:38 PM   #6 (permalink)
q3_abhi's Avatar
I think its probably a refresh rate problem. Try to keep it default.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 25-06-2005, 10:01 PM   #7 (permalink)
Biplav's Avatar
try decreasing the refresh rate.
if the refresh rate is set to higher levels then wat the monitor can handle then this problem occurs.
anyways not sure thoug but the same problem occured to be too
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 26-06-2005, 12:04 AM   #8 (permalink)
@expertno.1
1)5 years now
2) no shaking in windows mode
@q3_abhi
@biplav
Yes, most prob. it may be due to higher refresh rate then what monitor is supposed to work in. My monitor is a 5 years old Microtek 14" monitor. The max. refresh rate supported is 75hz. But since the time I've installed my new FX5200 AGP card, It also started working at 85Hz. So, I think that the problem may be due to that. I'll try to low my monitor's refresh rate.
Thanks
krish is offline
