05-06-2009, 04:02 PM
GONNA GET ALL OF YOU
MKV files
hy guys plz tell me how to open .mkv files....i ve matroska pack but cannot open them yet.......other than this i ve vlc player, media player classic installed on my system...its challenging one guys.....
05-06-2009, 04:43 PM
S60 rocks
Re: MKV files
VLC can play .mkv files
Proud Owner of N82! :cool:
05-06-2009, 05:10 PM
New Gen Guru
Re: MKV files
just install k-lite codec pack...and use vlc...thats it:-P
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
05-06-2009, 05:38 PM
Democracy is a myth
Re: MKV files
mkv extension is used for HDRips (well, my observation  ). VLC can open them but it stucks while playing them.
Try KMPlayer. Its better than VLC with lots and lots of features.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
06-06-2009, 01:10 PM
Gracias Senor
Re: MKV files
no need any separate codec packs, remove all the codec packs and players. download zoom player, after install, let it download the codecs. oce done, open the mkv files. enjoy the experience.
I am using only this player.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
06-06-2009, 01:50 PM
AMD user for 9 yrs!!
Re: MKV files
media player classic is better at playing those, windows media player 12 also plays it fine
06-06-2009, 03:20 PM
tHe nEw gEEk......ITian
Re: MKV files
if u have installed k-lite codec pack (mpc) on ur system........just re-install it........everything will be fine
06-06-2009, 10:12 PM
Re: MKV files
ve tried with vlc n media player classic......when tried with mpc it says cannot rendr the file...........
08-06-2009, 05:54 PM
Gracias Senor
Re: MKV files
^^hv u tried zoomplayer?
08-06-2009, 06:02 PM
Democracy is a myth
Re: MKV files
I've asked u to use KMPlayer, have u tried it?
08-06-2009, 06:12 PM
Re: MKV files
tried with zoom didnt work frn..bt zoom can play other mkv bt not thhis file..i thnk da file is currupt.......gna try with km 2mrw............
08-06-2009, 06:16 PM
Gracias Senor
Re: MKV files
^^gud u hv zeroed in on the real problem. Try KM and let us know.
08-06-2009, 07:40 PM
mera kutch nahi ho sakta
Re: MKV files
smplayer plays absolutely any file... except corrupt ones
jin files ka koi server nahi hota unka bittorrent hota hai
09-06-2009, 10:11 AM
Re: MKV files
try GOM Player, its a good one for MKV files
I mean it plays even those MKV files which gave problem in VLC,MPC for me
I hate all liars... except ;)
http://www.abhishekkr.co.cc
09-06-2009, 08:14 PM
Re: MKV files
so its the problem of corrupt file not the media type.........!!! Then there is less chance of working that.......
I play everything in mpc, mkv too.....!!!
09-06-2009, 10:54 PM
Re: MKV files
at last ...no player cud nt fulfill my wish...the file is corrupt i think
Search this Thread |
