Old 05-06-2009, 03:03 PM   #1 (permalink)
Default NEED REAL TECH GRU HERE..........
folks,,,,,,,,,
i installed the RC 1 provided by the digit dvd a couple of months ago and unwittingly used the compcln.exe option as well..\\
now that the sp2 is actually out i can;t install it as it requires the rc1 to be uninstalled wich i can't 'cos of the usage of compcln.exe
any help guys..........
utsavj is offline
Old 05-06-2009, 03:34 PM   #2 (permalink)
Default Re: NEED REAL TECH GRU HERE..........
which os you use i think its vista and which RC1 is it Internet Explorer 8 RC1.
abhijangda is offline
Old 05-06-2009, 04:33 PM   #3 (permalink)
it's vista's sp2rc1 and not IE's .............does neone really us IE these days.........
need help..........urgent
utsavj is offline
Old 05-06-2009, 04:35 PM   #4 (permalink)
utsavj is offline
Old 08-06-2009, 02:45 PM   #5 (permalink)
sorry i can't help you then i use xp not vista. But one way is to reinstall your os or try to repair it.
