I have a Athlon 2600+ on Asus A7V8X SE MB with 256 MB DDR 333MHz RAM OS is XP PRO SP2
For the past 1 month the PC freezes
occassionally when slightly memory intensive work like running multi apps, audio editing & playing Midtown Madness bundled with Digit Jun 05.
Once it freezes I restart & then too it freezes while running scandisk or during startup.
Since yesterday its become very frequent & I can't do anything on it.
Rt now it said It couldn't load the user profile (ADMIN)
and sent me to default profile. Where too it froze when I ran chkdsk from RUN... as some files were corrupted & the bubble keeps popping up.
Pl help me as I feel its some thing to do with the RAM being faulty ( its a yr old RAM) Check out the problems I have been facing:-
Here's a summary of some more problems:-
1. NAV 2003 freezes when doing complete system scan.
2. Defragmentation of C: doesn't take place even after 2 hrs (10GB partition) It remains @ 10 - 15%
3. Recently an error has started cropping up after I close IE 6.
iexplore.exe - Application error
INSTRUCTION AT "0x0190e10" referenced memory at "0x0128ad58". The memory could not be read.
Click OK to terminate the program.
What cud be the prob. There's no overheating prob..
