Old 24-06-2005, 09:09 AM   #1 (permalink)
arcticflare's Avatar
Default Disk doctor prob plz help
I have norton sys works 05 installed in win xp pro os. whenever i start the norton disk doctor to start hdd check i get a message saying that the os or a prog has exclusive access to this drive and disk checking can't continue under these conditions. plz suggest a way to check using disk doc and is it good to format hdd once every 6 months??
arcticflare is offline
Old 24-06-2005, 01:48 PM   #2 (permalink)
Just Do It
Charley's Avatar
Do u have Zone Alarm in ur system ?? I'd guess ti shud be due to a firewall
Charley is offline
Old 24-06-2005, 02:33 PM   #3 (permalink)
ya i have zone alarm pro 5.5.094. cud tat be playing any role in tis
Old 24-06-2005, 02:50 PM   #4 (permalink)
Just Do It
Charley's Avatar
Uninstall that and try
Charley is offline
Old 24-06-2005, 03:05 PM   #5 (permalink)
Is there no other option coz i cant uninstall entire firewall for a disk check
