After around 2 hours or more of doom 3/ HL2 the temperature are as follows:
CPU:63 C
ZONE 1 : 47 C
ZONE 2 : 50 C
HDD : 49 C
If I don't play games but surf net or watch movies/music for around same amount of time or more the temp. are as follows:
CPU : 52 C
ZONE 1: 44 C
ZONE 2: 47 C
HDD : 44 C
I used speedfan and intel active monitor to record the temp.
Are these temp. ok or high.
I am using:
P4 3.0 GHz Prescott with original HSF
intel 865gbf MOBO.
512 DDR (400 MHz)
80 gb PATA HDD
XFX Geforce Fx 5200 128 mb
400W PSU
Also have 2 exhaust fan at rear including psu fan, 1 blow hole on to for exhaust, 1 side panel fan as exhaust just above cpu and 1 intake fan in front.
Earlier I had the side fan as intake but it raised the temp. so reversed it.
Any help/suggestion would be helpful. Thanks
