Originally Posted by achacko@dataone.in
do you even know what link you gave him?
the link you gave him is completly
wrong, it is for DirectAdmin not for cpanel... and his problem is related to cpanel
so before providing any link make sure that you know what you are doing...
anyways back to the point..
what you can do it..try to re create the folder and place the files and see what happens...
and still things dont work then you might have to contact your webhost, he will be able to fix the problem for sure
Deep
