Old 23-06-2005, 11:29 AM   #1 (permalink)
Default Webmaster Plz Help !!
Hello Guys,
I wanna start a website and wanna use a content management system (CMS)
Out of all these which one is the best.
Drupal
Geeklog
Mambo Open Source
PHP-Nuke
phpWCMS
phpWebSite
Post-Nuke
Siteframe
Typo3
Xoops
Please keep these things in mind before deciding the ultimate CMS.
1. Search Engine Optimised Output (Phpwebsite claims to render pages that fully comply with W3C guidelines, so plz provide enough information on which CMS is better.)
2. Ease of use
3. Eye Candy
Lovedeep Wadhwa
cheetah is offline
Old 23-06-2005, 10:31 PM   #2 (permalink)
Version 2.0
Deep's Avatar
Till now I have used Mambo, Drupal and TextPattern...
Mambo - I didnt like it, it has too many options which makes admin panel complicated...and the code is also bad...(the html) so I wont suggest using it...
Drupal - Not bad, not bad at all...its very good infact..clean code..decent options...
TextPattern - Best if you are an advanced user, gives total freedom to play with the code, build pages...but you should know advanced xhtml for this (good knowledge of CSS and XHTML is must)
you can checkout demo of all here: http://www.opensourcecms.com/
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
