Old 30-05-2009, 05:06 PM   #1 (permalink)
Mohak's Avatar
Arrow WANT TO UPGRADE
Thid is my current configuration, as i got it from the store:
RAM - 2GB DDR2 SDRAM
GRAPHICS - NVIDIA GeForce 9300GE 3D 256MB
HDD - 320GB Serial ATA Drive
Processor - Intel Core 2 Duo E7300 @ 2.66GHz
Drive - SuperMulti SATA
Chipset - nForce 630i
Monitor - HP LCD 22''
I am not able to play games at full settings with this configuration, and want to turn it into a complete gaming rig. Can anybody suggest me what changes I should make to this so as to be capable of playing all the latest games as well as high definition movies, in the least budget possible?
Any help shall be well received.
Thanx
May Your Swords Stay Sharp
Mohak is offline
Old 02-06-2009, 05:46 PM   #2 (permalink)
Geekism RC1
Siddharthtech's Avatar
Default Re: WANT TO UPGRADE
Hey, upgrade your graphic card to an ATI Radeon HD 4870. It'll work. Mine cost me Rs 13000 and betcha it should be lower now. If it doesn't suit your budget, look for brands such as Zotac and Palit. About your RAM, you should just upgrade it to 4GB but in my opinion, 2GB is enough.
Siddharthtech is offline
Old 02-06-2009, 05:48 PM   #3 (permalink)
Geekism RC1
Hey, upgrade your graphic card to an ATI Radeon HD 4870. It'll work. Mine cost me Rs 13000 and betcha it should be lower now. If it doesn't suit your budget, look for brands such as Zotac and Palit. About your RAM, you should just upgrade it to 4GB but in my opinion, 2GB is enough. Rest of your configuration is absolutely alright. If you have some gaming problems, try Advanced System Care v3.0 freeware software. It has an application called Game booster which really boosted my PC gaming Experience. Gotta go....
