Old 30-05-2009, 04:02 PM   #1 (permalink)
hansraj's Avatar
Default External HDD fails to show the content....!!!
SOS........ My 120 gb HD has a lot of data..and it shows only one empty $recycle.bin (which is a system hidden file) but surprisingly it shows the 111 gb occupied (which is correct and the actual data content before it stopped showing the files/folders). Also i noticed few files which I know are present in the external HDD, when i try to copy them again in the disk it says do you want to replace!!!!!!! But still none of the files are visible. How to retrieve the data back???
Show hidden files, show system files is all chekced in my folder options........
PS: Last i used this HDD in one of my friends pc and some virus was detected there which was deleted by his antivirus.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 01-06-2009, 03:24 PM   #2 (permalink)
Lightbulb Re: External HDD fails to show the content....!!!
I had a similar problem with an ext HDD. It usually happens when the HDD is forcibly disconnected. All i did was shut down the comp, attach the disk and restart. Then the comp performed a disk scan and all my folders were recovered!
giovanni is offline
Old 04-06-2009, 07:20 AM   #3 (permalink)
hansraj's Avatar
Default Re: External HDD fails to show the content....!!!
Got my problem solved................ did a chkdisk and it recovered all the data........
hansraj is offline
