Old 22-06-2005, 06:07 PM   #1 (permalink)
Default DDR400 RAM doubts..
Looking to purchase RAM.
I am looking for 2*512 DDR 400 RAM chips to operate in Dual mode for an Intel 915 mobo and P4 3.2 GHZ. Budget Max 6-7k.
Have been told that Kingston's 512 DDR 400 is at 3k..
I think it would be the value RAM.. Can someone tell me which kingston ram model wud work in Dual model.
Model number/detail Would be appreciated..
Went thru kingston's website but there are a myriad of options there.. Also how will the RAM be connected in dual mode when installing in the machine.
Thanks,
imjimmy is offline
Old 22-06-2005, 06:58 PM   #2 (permalink)
if corsair is supported take it if you don't wanna oc
corsair value select cas 2.5-3-3-8 for 5824 with tax in delhi
akshayt is offline
Old 22-06-2005, 07:36 PM   #3 (permalink)
siriusb's Avatar
Default Re: DDR400 RAM doubts..
Thanks,
Hey.
There is no special ram model or anything for dual channel. Any ram that the mobo supports when put in the correct channel (channels => mem banks) will give the appropriate channel. Most mobos color code the channels (blue and black). Just put one mem stick each into slots of the same color (A few mobos have different coloring schemes, so read the manual apriori).
Just buy the ram with the lowest latency for your price and all wil be fine
siriusb is offline
Old 22-06-2005, 08:56 PM   #4 (permalink)
Just confirm from the person you buy and with the box etc,manufacutrer or mobo and ram etc that your cpu,mb,ram all run in dual ch
akshayt is offline
Old 23-06-2005, 10:44 AM   #5 (permalink)
Thanks for all your replies.
I'll be purchasing Kingston 2*512..
I think it is value RAM starting with KVR- it will be DDR400
I will ask the seller for compatibility with the Intel D915GAV mobo.
BTW..will this RAM also work with a AMD s939 MSI RS480M2-IL mobo with a AMD 64 3200+ Winchester proccy?
Thanks,
imjimmy is offline
Old 23-06-2005, 12:58 PM   #6 (permalink)
The Hardware Labs
mohit's Avatar
Thanks,
ya it will surely work. no probs there.
mohit is offline
Old 23-06-2005, 03:42 PM   #7 (permalink)
rohanbee's Avatar
I have the same ram PC-3200 400mhz on my 915-gav, it will work.
Theoretically they say that dual channel is different from standard ram. But actually i think its just another way for these companies to make money. They all seem to work the same way. They just put a different tag to make some more bucks!!!
Quote by Garfield'
rohanbee is offline
Old 24-06-2005, 12:35 AM   #8 (permalink)
Hynix 512 MB 400MHz RAM -2000 bucks! Y not this?
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 24-06-2005, 11:41 AM   #9 (permalink)
Good buy! I have 2 of these. No worries.
-Keith
Keith Sebastian is offline
Old 24-06-2005, 11:47 AM   #10 (permalink)
I was also told that the best performing RAM are Corsair, Transcend and Kingston - in that order.
Don't know how good Hynix is..
[/quote]
imjimmy is offline
Old 24-06-2005, 03:32 PM   #11 (permalink)
The difference is when you put the RAM in Dual Channel. There are no such thing as "dual channel memory sticks." IT's just the configuration that makes the difference between RAM in dual channel and in standard modes.
Nemesis is offline
