Old 10-09-2004, 12:51 PM   #1 (permalink)
Default Machine moving at snail speed.
I have an AMD Athlon XP 2400+ CPU,with 256 DDR RAM,a 20 GB HDD,a cdrom & a DVD ROM drive.Recently,I installed Suse Linux & also uninstalled it , but created some new partitions by mistake.Now the problem is that,all programmes are running unusually slow, viz when I click on I.E it takes around one minute to open while previously it opened immediately.I have two fans and both are working properly as it seems from the outside of the cabinet.
What could be the problem? Is the processor getting too hot or is there some virus infection? I have Norton 2003.Please help at the earliest. Where do I find a software to monitor the CPU's temperature?
harpoon is offline
Old 10-09-2004, 12:55 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Have u deleted th partitions that u created by mistake ? If so, then th delay may be due to th fact that Windows is searching for th deleted partitions in th background. Please explain in detail, exactly what u hv done.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 10-09-2004, 05:04 PM   #3 (permalink)
Default Yes, I had deleted two partitions.
Yes,although now I have two new partitions I had deleted two partitions previously.
harpoon is offline
Old 10-09-2004, 05:23 PM   #4 (permalink)
defragment ur disk
clean ur registry
make start up items minimum
search the forum
the only problem is that ur disk must be too fragment cuz of this .. thats abt it
also remove and merge unwanted partitions
No Mercy, No Limits.
theraven is offline
