Old 28-05-2009, 11:55 PM   #1 (permalink)
napster007's Avatar
Default suggest a PC at 40k
hi all,
As i'm now entring the 2nd year of my college...i thought it was about time i got my own PC. so i need suggestions from u all. I need to assemble a PC including the monitor. for not more than 40-45k. can u ppl please give in ur best views.
there are only 3 conditions from my side...
1) a big lcd monitor....most prolly 22"
2) a decent gpu to run games on that monitor.
3)cpu which is not a underperformer.
plz give me ur opinions asap...
napster007 is offline
Old 29-05-2009, 07:04 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: suggest a PC at 40k
1) Phenom II X3 720: 7.5k
2) Jetway HA-07 Ultra: 6k
3) Corsair XMS2 2x2GB DDR2 800MHz: 3k
Total : 16.5k
4) Sony DVD burner: 1.1k
5) Logitech/Microsoft k/b+laser mouse: 2k approx
6) Corsair VX450W: 4k
7) Cooler Master Elite 332 Cabinet: 2k
8) Seagate 500GB HDD: 3k
Total: 28.6k
9) Samsung 2233SW 22" FullHD: 10.5k or Dell S1909W: 7k
10) Palit GTS 250: 9.5k or Sapphire HD4770 : 7.2k
desiibond is offline
Old 29-05-2009, 08:49 AM   #3 (permalink)
napster007's Avatar
instead of a amd... can u give me a intel solution?
Old 29-05-2009, 08:57 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Processor: E8200: 8.5k or Q8200 for same price.
Mobo: MSI P45 Neo-f: 5.5k-6k
Old 29-05-2009, 08:58 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
But seriously speaking, E8200/Q8200 won't match the speed and power of X3 720. That's for sure. And if you want quad core, get X4 920.
Old 29-05-2009, 09:10 AM   #6 (permalink)
napster007's Avatar
so ur sure i should go for the amd setup?? i mean i had been using intel all my life.... i'm open for the amd too, but fi i'm going for the amd i want to be sure if the x4 will be better than the quad?? and is it the same price? performance wise speaking is it better?
Old 29-05-2009, 09:25 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
X4 920 competes with Q9450 and Q9550. And if you do not overclock like hell, I would suggest you Gigabyte MA78GM-US2H for 5.1k else go for Jetway HA-07 Ultra (crossfire support)
And I am pretty sure about Phenom II. The only competitors to X4 940 are Intel Quad Extreme and i7.
Old 29-05-2009, 03:08 PM   #8 (permalink)
napster007's Avatar
so the X4 will fit into my budget right?
Old 29-05-2009, 03:12 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes.
Old 29-05-2009, 03:17 PM   #10 (permalink)
napster007's Avatar
thank you for the awesome support... i'll now make a final list with the X4......
ok 2 more questions,
1) how much is the X4 for
2) should i go for the GTS 240 or the 4770, which is a better choise and will they be able to handle games at 22"
Old 29-05-2009, 03:46 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
X3 720 B.E. 2.8GHz @ 7.8k(unlock to X4)
Biostar TA790GXB A3+ @ 6k
Samsung 2233Sw 21.5" FULL HD @ 10k
Palit GTX260 SONIC @ 11.5k
Corsair VX450W @ 3.9k
Rest upto you.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 29-05-2009, 03:47 PM   #12 (permalink)
Bond, Desi Bond!
desiibond's Avatar
X4 price starts at 10.5k I think
you might get it for lower price. Someone in the forum said that the price is 9.5k.
You can couple it with Gigabyte MA78GM-US2H if you want to do moderate overclocking and Jetway HA-07 Ultra for extreme oveclocking.
Either go for HD4770 or go for HD4870/GTX260.
with little bit of overclocking HD4770 almost reaches GTS250's performance and it still runs cooler
But if you are going to get a fullHD display, you better get GTX260.
Old 29-05-2009, 03:59 PM   #13 (permalink)
j1n M@tt's Avatar
Thumbs up Re: suggest a PC at 40k
Total : 16.5k
Total: 28.6k
^^+1
this is better than the Intel solution if not overclocking
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 29-05-2009, 04:36 PM   #14 (permalink)
napster007's Avatar
ok so this is what i have come down to:
1)X4 : plz specify model....till max 10K
2)Jetway HA-07 Ultra: 6k
3)Corsair XMS2 2x2GB DDR2 800MHz: 3k
8)Seagate 500GB HDD: 3k
10)Sapphire HD4770 : 7.2k
any cut off i can make in this?? or any chance the actuall prices are cheaper??
Old 29-05-2009, 04:58 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Y the heck are you going for a HD4770 if you want FULL HD gaming?
About me:
Old 29-05-2009, 06:49 PM   #16 (permalink)
dOm1naTOr's Avatar
Originally Posted by j1n M@tt View Post
^^+1
actually its good only if overclocking. At stock, quads like Q8200 wud be better.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 29-05-2009, 06:51 PM   #17 (permalink)
napster007's Avatar
is the HD4770 not done for the 22" HD?? or will it suffice because the other options make my budget shoot very high
Old 30-05-2009, 10:32 AM   #18 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
- Get X3 720 B.E.
- Get GTX260/HD4870 1GB
About me:
