Originally Posted by expertno.1
man try this software
Tweakmaster..award winning internet speed booster utility and tweaking utiliy for internet...it guarantees you for this....
www.tweakmaster.com(shwarewre)
or try a freeware called INTERNET SPEED BOOSTER
do some spyware check aslo..there r many
slo use good downlaod managers like DAP PREMIUM and FDM
this will surely increase ur speed
also check if ur connection speed is really 256 or not and getting speeds of 32 is possible or not
visit www.testmy.net
this will solve ur problem
ALSO
MANy threads are there to increase the internet speed ..please search teh forum before u post...
hi, very thanks for the suggestions, i ll work on them and post the reply. btw, i already tested in testmy.net, i get 200 kbps around.
@club_pranay
i am pretty sure abt the kbps and KBps even before u could reply. nyways thanks. i dint have any confusion reg. the math over there.
@bharat_r
i knew 100% is not achievable and i needed only a reasonable speed!
mine is too low to be called a 256.. thou i pay for the same!
@achacko@dataone.in
@club_pranay
the speeds u get are only momentary speeds.. that is caused by the delay.. during which the data is in the modem buffer from which tehy are transferred all of a sudden to ur system which makes sudden hike in the speed as it recognises only then. nothing other than that.
@futuristically_ancient
noway can u get 39KBps with 256kbps CONSTANTLY.. if so, then u are the most luckiest person in the world... for its more than 256..
/legolas.
