I Finally decided to change to aMd and decided to buy the Asus A8N-E Motherboard. I had two doubts.
1. I already have 1GB DDR Ram in my present system running at 400Mhz and Everest Home Edition says that the latency timings of the RAM is 3-3-3-8. I wanted a better performance RAM, so could someone advise me what to look for and which is the best timings. I wanted to buy the best DDR Ram out there in india so if some one could mention a dealer and their phone number it would be nice
2. The catalogue said the motheroard supports SATA II will there be a problem if i use my existing SATA hard disks. Are there any SATA II Hard disk in india?? Which Brand?? Where can i get it??
One ore doubt not related to the topic, will there be a performance drop when i use two programs at the same time between amd and intel??
