recently i bought a DDR kingston 3200 400Mhz 256MB
the vendor said its backward compatible with my KOB845 Ndsmx which only supprots upto the speed 266Mhz
so my doubt is that when i tested it with the CPU.exe frequency tester which came with the digit cd it only shows the ram frequency as 133.6 mhz
i have searched some sites and found out that the
"DDR-266: DDR-SDRAM memory chips specified to run with 133 MHz"
is this correct or should the test show 266mhz instead of 133.6
waiting for a reply
