Re: Net connection too slow
If you have 256kbps speed then you should get near about 32Kbps of downloading speed....
If there is a lot of activity(such as gaming, downloading torrents etc) from the other subscribers then it may slow up your downloading speed.
Did you try optimizing your Internet Connection using TuneUp Utilities or TCP Optimizer. Try doing that. And also try downloading with IDM.
If you have any firewall enabled, close it and try as it may block some ports....
Also try disabling Qos Scheduler which takes up 20% of your bandwidth for Windows!
Click Start-->Run and type gpedit.msc and press enter.
Doubleclick on Adminstrative Templates-->Network and highlight Qos Scheduler. On the right pane, doubleclick Limit Reservable Bandwidth.
Click on Enabled and changes Bandwidth limit to 0% and click OK.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
