Originally Posted by vaibhav_jain
budget of Rs.20000(minimum) and Rs.25000(maximum).
I have always used AMD and made PCs for my friends on AMD config so I can suggest on that
so here i go..
1. Processor.. X2 5000+ or 7750 BE is good if price diff is not much you can buy that.
incase you can adjust the budget to Quadcore that will be better. first check other components then decide if you get Quadcore at good rate..from some dealer
2. Corsair? ... if you intend to overclock then only buy High End Corsair.
Corsair value ram, Kingston or Transcend. Buy which one is cheap.
Buy Transcend or Kingston 800fsb 4GB (4 x 1GB/ 2 x 2GB dual channel)
yes you read it right buy 4GBs bcoz you can use the x64 OS more effectively.
if you think the price is on the rise and might come down then buy 2GB now and 2GB latter.
3. Motherboard .. Gigabyte GA-MA78GM-S2HP (or S24P) post the link of the two motherboards specification i will suggest which one is better of the two.
4. Take 500GB sata..
if he is using is gong to use it for movies and gaming... then I suggest put two HDD in Raid - 0 and check out the performance. the data transfer rate at twice .. way better.
5. Optical drive.. any liteon-sony-benq all works same. buy 20x sata which one is cheaper. incase u want lightscribe.. and want to fool friends buy that.
6. Monitor ur choice.. i say
ASUS 18.5" --- 6.1k / Viewsonic 19" --- 6.5k / DELL 19" --- 7k {dont know the exact price.}
7. Speakers:- I purchased Philips . for 1300 yesterday for cousin.. model no dont remember it had 30watts output but I say buy 5.1 atleast ... and feel the music and gaming.. even the low end costs less than 4k now.
8. KB+Mouse-: Logitech Internet Pro or any Microsoft wired combo which one looks good to you.. unless you go for wireless.
9. Cabinet-: STRONGLY RECOMMEND -
COOLER MASTER ellite-334
Buy it from SMC .. they have it.. its beautiful.
10. UPS-: Powersafe or Microtek or APC .. BUY one with 2 batteries
11. Pen drive: Kingston 4GB mini .. that fits in wallet
12. place.. already mentioned above. in wazirpur - Crux Computronix but price varies from nehru place.
