Old 19-06-2005, 05:26 PM   #1 (permalink)
Default perl-database help
I need help from u guys, relating to the matter of perl and mysql. When I use the DBI module downloaded from search.cpn.org, like this-----
Use dbi;
The apache error log, shows the following error,
Can't locate loadable object for module DBI in @INC..............
I even downloaded the lats perl release but it did not help either. Can anyone please help me out.
sridhar8310 is offline
Old 20-06-2005, 09:31 AM   #2 (permalink)
Version 2.0
Deep's Avatar
I am not into perl at all but i think google knows the answer..
i did google search about the problem and found this solution..
make sure to give mod_perl's Makefile.PL PERL_UTIL_API=1, EVERYTHING=1 or DYNAMIC=1 parameters to enable and build all the components of Apache::Util.
check this page out http://bulknews.net/lib/mod_perl_gui...eshooting.html
see if this can help you or not..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
