Old 19-06-2005, 05:22 PM   #1 (permalink)
Default limited access... guest user..
hi guyz...
i want something that allows only admin users to execute a few applications and restricts guest user to exec them in win xp pro....
generally the apps are games...
thanks in advance...
BlueStag
rahulkunduru is offline
Old 19-06-2005, 06:09 PM   #2 (permalink)
You could create a new account under the" Restricted User" group.
Start>Run>control userpasswords2>Add> Give the appropriate details & select restricted as applicable.
A restricted user can save documents but cannot install applications or change system settings.
www.Oobertech.net
digen is offline
