Old 14-05-2009, 09:08 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default external HDD, needs to be online all the time
i need an external HDD 500GB +, the purpose will be to dump all my data on to that and use my internal disks to play around, i will be installing multiple OS's learning GRUB and stuff like that and doing so i will be installing and reinstalling OS's. so this external HDD should be able to take the load and stay online.
one option for me is to buy internal HDD and than a casing, the problem with this is that my friend had the same thing and it did not work properly it went ofline and once it crashed, all in all it was not stable.
can any one suggest whats the best option i have and please post the price too.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 15-05-2009, 01:24 PM   #2 (permalink)
Default Re: external HDD, needs to be online all the time
Most probably your friend went for the notorious Seagate 7200.11 drives . You could go for HDD + casing combo and use a WD HDD in it.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 15-05-2009, 06:24 PM   #3 (permalink)
chicha's Avatar
can you please post the different variants of WD HDD with prices.
chicha is offline
