Old 19-06-2005, 10:47 AM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default flashget error!
i just d/led flashget recently. it worked fine for a few days. then , whenveer i started a d/l, it shuts down automatically after a few seconds. only the icon in the system tray remains.when i move my mouse cursor over it, that disappears too. what is the problem?
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 19-06-2005, 11:14 AM   #2 (permalink)
Just Do It
Charley's Avatar
http://www.amazesoft.com/faq.htm
Chck this site for the soln
Charley is offline
Old 19-06-2005, 12:59 PM   #3 (permalink)
nix
Senior Member
nix's Avatar
Default hmm
hey thanks for the faq URL.
it says i have to delete cd_clint.dll, but that dll isnt there in my comp. i guess i have to wait until they release new version.
nix is offline
Old 19-06-2005, 03:18 PM   #4 (permalink)
I too had similar kinds problem but, I unistalled it and then again installed it and it is working fine.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 19-06-2005, 05:11 PM   #5 (permalink)
selva1966's Avatar
Nix I also had exactly the same problem. I also thought of putting this question before this forum. As a last measure I reinstalled not once or twice but thrice and now it is working fine. So you can do the same and reply.
selva1966 is offline
Old 19-06-2005, 07:16 PM   #6 (permalink)
I faced this problem but i uninstalled flashget 1.65 and reinstalled the older version 1.40
It is better to light a candle than to curse the darkness.
Shikhar is offline
Old 19-06-2005, 11:53 PM   #7 (permalink)
desertwind's Avatar
cd_clint.dll is located in windows directory. Delete it and you problem is solved
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 20-06-2005, 09:20 AM   #8 (permalink)
Version 2.0
Deep's Avatar
This has been posted earlier too...
check this..
http://www.thinkdigit.com/forum/view...light=flashget
This is what I had replied..
....What i suspect is, you are using ad version of flashget which shows banners on top and sometimes it causes the problem...
so its better to use shareware version...
the solution to this problem, as mentioned by flashget people is to delete cd_clint.dll under windows system directory let flashget work at shareware mode.
check this - http://www.amazesoft.com/faq.htm#b34
I hope this helps you.
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 20-06-2005, 02:10 PM   #9 (permalink)
Just Do It
Charley's Avatar
Default Re: hmm
Do a search in the DOS mode as "dir Cd_clint.dll /s/a/p/o/w" .... Track the directory where u find it and get rid of it.
Hope u should find it soon.
Charley is offline
Old 25-12-2006, 11:42 AM   #10 (permalink)
24online's Avatar
Default Re: flashget error!
take latest version... with torrent support...
24online is offline
