Old 18-06-2005, 10:56 PM   #1 (permalink)
dinesh_singh
Posts: n/a
Default i m intrested in sify braodband...shuld i go 4 it????
i m currently having a reliance dial up conn. at 115 kbps and it costs me 1500+10%tax monthly.i m a downloading freak and get a downloading speed of about 7-10 kbps regularly...and i need more.
in my city only sify is availabe except for bsnl dataone who has data limitations on every plan.and i hate listning data limitations.
so i wont never go for ant data limiting plan.
so my choise is only for sify.
the problem is.....can any body tell me what the speed he gets in the plan he is using....
or tell me the downloading speed in 64 kbps ,128 kbps and 256 kbps plan.
Old 18-06-2005, 11:15 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
1st off all the biggest question is how much u r willing to pay...
& then try this bellow points....
for that u have to look for a unlimited plan... which will not have any data limit...
064 KbpS means downloading of 5-6 KBPS
128 KBPS Means downloading of 9-10 KBPS
256 KBPS Means downloading of 15-20 KBPS
this all depends on the trafic... but the useual way is to count 1/10 of the browsing speed....
so if u can aford u can even have 2GBPS Bharti connection....
Choto Cheeta is offline
Old 18-06-2005, 11:57 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
I get 10-11 Kbps on 48 Sify connection.
navjotjsingh is offline
Old 19-06-2005, 12:27 AM   #4 (permalink)
@dinesh Iam using the Sify Night Unlimited 128KBPS Plan (9 pm-9am)....mind you this is the shared bandwidth....download speeds are around 12-14 (on avg).....this is a really cheap plan....only Rs 400.....you can go for Night Unlimited 256 KBPS plan which costs around Rs 650....I would suggest you to take any of the Night Plans along with a Limited 300 MB Download @ 256KBPS plan(which costs about Rs 300-Rs400)....this combo will enable you surf during daytime and download as much as you want during the night time....
sahil_blues is offline
Old 19-06-2005, 12:27 AM   #5 (permalink)
Sify is really good now except the 150MB/day download limit.
Go for 48kbps unlimited connection for Rs450/- and u will get download speeds of 12-13KB/s equalent to 128kbps connection.
All the users of 48kbps plan are getting these speeds believe me.
But if u overcome the laxmanrekha i.e. 150MB/day (4.5GB/month) one day of your validity will be removed.
But downloads in the night time wont be counted.(10PM-8AM).So u can download 150MB from 8AM - 10PM and unlimited from 10PM-8AM.
Overall its good.
Mahesh Babu is offline
Old 19-06-2005, 02:20 AM   #6 (permalink)
Jags's Avatar
dude... get ur facts right.
Sify Night Unlimited 128kbps Plan is not shared...its the 256kbps which is shared.
If u don't believe my words check this pic taken from sify's renewals-plan page
for the "1 mth NIGHT UNLIMITED 128 kbps" plan "service speed" is given as 128kbps (and nothin else)...while in the "NightUnlimited" plan ""service speed" is given as UPTO 256kbps... and i think we all know what upto means.
I also have a 128kbps plan...and in my plan description it just says 128kbps...if it had been a shared one they wud have mentioned it in the description itself.
I know this because i earlier had a 64kbps shared plan.
this is what my plan descr currently says:-
Jags is offline
Old 19-06-2005, 03:08 AM   #7 (permalink)
dinesh_singh
Posts: n/a
THE POINT IS I KNO THE PRICE OF PACKAGE.
I NEED ATLEAST 25KBPS ALL THE TIME AND I HAVE TO STICK WITH SIFY COZ THIS IS THE ONLY OPTION FOR ME.
Old 19-06-2005, 03:20 AM   #8 (permalink)
Follow what Shail bhayya suggested. as night packages dont have downlood limits.
Old 19-06-2005, 03:22 AM   #9 (permalink)
Jags's Avatar
the reliablity of sify's internet depends alot upon their last mile i.e. ur local sify service provider (usually cable operator).
sify's internet is divided into two parts:-
1) local gateway (this is maintained by ur local sify service provider)
2) SAM server (maintained by sify)
u will rarely have any problem with the SAM server
(once in a month...max)
but if ur cable operator is an a**hole then no one can help u.
i know this because my cable operator is one.
I have a 12 hr/day connection (9am - 9pm)...but my net breaks down atleast 2 hrs every day.
when i talked to my cable operator he says that he can't do anything as there is no staff during night.
so before going for sify's connection make sure that ur cable operator have a staff that works during night.
and one more thing... the price mentioned on sify's site does not include ur cable operator's maintainence charge...they cud charge anywhere b/w 50-300 RS.
Suppose u r going for 128 night plan..then u will have to pay Rs 400 + maintainence charge.
to know more about sify's internet visit:-
http://forum.seo4india.com/
Jags is offline
Old 19-06-2005, 03:30 AM   #10 (permalink)
My cablewaala charges a nominal Rs30/- per month
Old 19-06-2005, 08:07 AM   #11 (permalink)
Rebooting
r u sure....
Old 19-06-2005, 09:07 AM   #12 (permalink)
Better stay away from sify ... they are totally unreliable, and most of the package names are misleading. Unlimited connections have a limit of 150MB/day, and really you are at the merci of your local cable operator.
Just check this link http://forum.seo4india.com/index.php...b&showforum=21
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 19-06-2005, 09:30 AM   #13 (permalink)
expertno.1's Avatar
Can u all believe this---
I get the speed of 6 KB/s on 14.4 k connetion at night (using DAP)
and 3-4 KB/s in daytime (using Dap)
and 2-3 KB/s in daytime without and downlaod acclerator
expertno.1 is offline
Old 19-06-2005, 09:50 AM   #14 (permalink)
arcticflare's Avatar
48Kbps pm @ rs450 is good package and speeds are hovering btw 10-12KBPS most of the time. Reliability doesnt seem to be an issue for me tho
arcticflare is offline
Old 19-06-2005, 12:01 PM   #15 (permalink)
ashisharya's Avatar
go for 48 kpbs unlimated plan. it will give u 10-14 kpbs.
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 19-06-2005, 02:35 PM   #16 (permalink)
dinesh_singh
Posts: n/a
in my city this 48 kbps plan doesnt available.
and i visited a few frnds of mine using sify.
they are in a hell....
and i wont get a sify....in my life
pertilarly in my city chandigarh....sify sucks and i m waiting for better plans form bsnl and reliance to come wich will be in july i think.till then i m sticking to reliance.....atleast i never get a problem and never get speed below 9 kbps
thank u guys...
u helped a lot
thanx a lot for ur help
Old 19-06-2005, 08:49 PM   #17 (permalink)
Sify in Chandigarh sucks a bit "extra" I hear
Someone I know shifted to delhi to get away from sify there ...
ujjwal is offline
Old 20-06-2005, 01:28 PM   #18 (permalink)
dunno bout the situation up there in chandigarh , but m totaly satisfied with sify .
1st i had the 256 kbps night 1 , which gave me 30 - 31 kbps 4 the 10 hrs . i usually downloaded bout 1 GB per night
now due 2 my req , have taken the 128kbps n download with it the whole night , bout 500 MB per night . n surf n download a bit during the day
no probs 4 me d00d
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 20-06-2005, 01:46 PM   #19 (permalink)
Just Do It
Charley's Avatar
I had Sify in my mind before Dataone came by.. What more many of the Sify users say that the connection is not as good.
Charley is offline
Old 20-06-2005, 06:17 PM   #20 (permalink)
Yes Sify is good
Even the network downtimes are less now.
Speeds are good.
Old 20-06-2005, 08:30 PM   #21 (permalink)
My cablewala charges Rs 0/- month. Can't beat this.
Delpiero is offline
Old 20-06-2005, 09:13 PM   #22 (permalink)
dinesh_singh
Posts: n/a
( sify sucks here people are complaining...
such a good sity and no good quality broadband service....(
reliance dialup is the best.
Old 20-06-2005, 09:26 PM   #23 (permalink)
People are complaining because Sify has applied download limits even on unlimited accounts.But u can take night accounts for downloading.
And also it depends on how good your cable bhayya maintains the network.
But saying Reliance is better than Sify is craap.
U will enjoy better speeds on Sify than on Reliance.
On Reliance u will get speeds of 10-12Kb/s on 256 kbps connection its really horrible.Even on Sify 48kbps pack u will get 12-13KB/s downalod speed.
Old 20-06-2005, 10:09 PM   #24 (permalink)
That's true. Sify does give 11-12 kbps on just a 48kbps connection. Sify is just great IMO. I don't have any problems with it. And i recommend it to everyone.
Delpiero is offline
Old 24-06-2005, 06:37 PM   #25 (permalink)
My Goodness!
U people r in which part of India????
I use a BSNL Dataone 256Kbps connection & it gives me upto 29KBps download speeds & 1GB DU/UL limit per month. All costin just 500/- a month? I voraciously do surfing & downloading still I have used only 50% of my limit!!
No ISP can beat that coupled with good service.
I used Sify dial up for 3 yrs. They start cheating u after u renew ur connection once.
All that 48kbps is nonsense.
I get at times 48KBPS download speeds.
U got an answer for that, let me hear it.
Sorry if am sounding rude. But I just don't get the idea of being misled with measly surfing speeds.
The private Broadband ISPs & cablewallahs aren't even present in my area of all places in Ahmedabad.
Adios
Nitin
[email]armourlength@gmail.com[/email]
armourlength is offline
Old 24-06-2005, 07:29 PM   #26 (permalink)
Dude I can finish off 1GB in 1 day on 256kbps connection.I don't think u downlaod much like movies,songs,games,etc..etc..so u are satisfied with that tariff.But for hardcore internet downloaders it is nothing but BULLS#HIT.If they continue the 1GB limit after 30 June then all will say BSNL is BULLS#HIT.And there is no unlimited option in BSNL.
And u are saying that u can sometimes reach 48KB/s download speed.
Ha ha i can reach 200KB/s sometimes on Sify.
Check this screenshot
Edit[Nemesis]:Image removed because of link to possibly illegal Cricket 2004 download
and by the way sify also provides 256kbps 1GB limit package for Rs 550.
Old 29-06-2005, 01:50 PM   #27 (permalink)
Default Then go for higher rates
Babu,
I am a normal user, but 1st pl check up BSNL and go for the better plans which might suit u.
What the hell will u download worth 1 GB??????
Adios
Nitin
Old 29-06-2005, 02:39 PM   #28 (permalink)
Just Do It
Charley's Avatar
Are the Newdelhi sify users going bonkers???
WTF, how do u get a speed of 11kpbs/12kpbs on a 48kpbs connection. that comes between 88&96 "KPbs". U have a 48KPbs connection and u get 88/96 KPbs ?
It will never happen..
Charley is offline
Old 29-06-2005, 04:26 PM   #29 (permalink)
Default Re: Then go for higher rates
Originally Posted by armourlength
Babu,
N00b ........... he finds 1 GB too much .........1 GB isnt even 1 movie....when u can dld so many in a month!
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 29-06-2005, 05:17 PM   #30 (permalink)
achako@dataone.in - actually it does happen, all unlimited plansm from 48kbps to 96kbps get the same speed of 11-12kBps, for the past 3-4 months.
Sify is quite good in terms of speeds, but it creates new lows in other things, for example there is a daily limit of 150MB on all "unlimited connections", pings are blocked, and many non-mainstream applications like torrents, p2p clients, irc are blocked.
If you want to just browse web pages and access chat rooms, sify is actually quite good. But for downloaders, irc users, newsgroup users, or any other type of user classified by them as "abnormal", sify is just terrible.
ujjwal is offline
