Re: Dual Channel RAM (Second Set)
if u want to maintain the dual channel config ... then u should use 2 X 1 GB sticks. and if u want to leave the upgrade path open, then go with one 1 x 2 GB stick so that one slot will remain free for future upgrade. As Dual channel dsnt make much difference in day to day work, and 5-10% at max in gaming.
Choice is urs.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
