Old 18-06-2005, 02:59 PM   #1 (permalink)
Default Plz Help me- I Want Upgrade My BIOS
Hi I have Intel 810i Chipset Based "Vintron MotherBoard & Intel Celeron 1.10ghz CPU(370 pin Socket) With 256MB SD-Ram Samsung 40Gb HardDisk & Samsung CD-ROM & CD-RW and Adcom tv Tunner Card & Creative 2.1 sound Card.my Problem is that when i insert the Windows XP bootable in My rom.win xp not boot from CD-Rom. I change my Bios setting. But Result is nill. But Windows 98 is always boot from Cd-Rom. so, i want to Upgade my Bios. My Bios Detail is That:-
Program: eSupport.com BIOS Agent Version 3.41
BIOS Date: 02/01/02
BIOS Type: Award Modular BIOS v6.00PG
BIOS ID: 02/01/2002-i810E-47M102-7401E2C
OEM Sign-On: ATC7401E2 PIII/Celeron i810/E+ICH2 Vintron Rev:1.0r03
Chipset: Intel Whitney 82810E rev 3
Superio: SMC LPC47M10x rev 0 found at port 2Eh
OS: WinXP
CPU: Intel Celeron(TM) 1100 Mhz MAX: 1500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 384 MB
Memory Maximum: 1536 MB
Memory Slot 01: 128 MB
Memory Slot 02: 128 MB
Memory Slot 03: 128 MB
o, plz tell me right Bios Version for my PC. and which Website i can download Bios.and my anotherproblem is that i am unable to find Vintron Mother Website And AdCom website for Tv Tuner card Driver. so, plz any body help me.
rohtak2001 is offline
Old 19-06-2005, 04:21 AM   #2 (permalink)
Unfortunately, ATrend, the maker of your motherboard, is nowhere to be seen on the Internet, so I guess you cannot upgrade your BIOS.
Vintron itself has virtually disappered from the market, so I guess there is not much you can do.
Last edited by Happy Bytes: Today, at 3:45 AM. Reason: added a signature spreading worm....
AcceleratorX is offline
Old 19-06-2005, 06:31 AM   #3 (permalink)
sidewinder's Avatar
if ur comp is working perfectly then dont even think of a bios update.One little mistake.....nd u just might have to through ur mobo in the dustbin
Bombina rocks
sidewinder is offline
Old 19-06-2005, 07:58 AM   #4 (permalink)
Can you give me Vintron & Adcom Website Address
Old 19-06-2005, 08:12 AM   #5 (permalink)
q3_abhi's Avatar
If u no how 2 update the BIOS, then only go 4 it.
However it is not recommended that u upgrade ur BIOS.It can b risky.N powercuts during upgradation can prove 2 b fatal.
q3_abhi is offline
Old 19-06-2005, 09:42 AM   #6 (permalink)
expertno.1's Avatar
Upgrade the bios only if u have any problems otherwsie upgrading the bios will not be helpful and is not recommended
expertno.1 is offline
