hello i am going to build an entirly new rig whcih i intend to use for my course in 3d animation and to play games let me make it claer cost is not hat much of factor as performance is mor eimportant for me especialy with software like maya 3d studio max please give me suggestion
as i will be living for mumbai next week so i will see if i can buy some of the parts there below is is some of the stuff i intend on buying please comment
proccesor i want to go for an amd processor amd anthlon64 bit 939 3500
please suggest a mother bord for the same card i heard a alot abot sli mother board can u tell whats that if possible tell me a sli motherboard also i was go through
www.anadtech.com and foun about anew proccesori have linke below to that page
http://anandtech.com/guides/showdoc.aspx?i=2426&p=2
Athlon 64 4000+ 90nm (Retail) - San Diego core will this proccesor be avilable in india
also i heard a lot about dual core is it wort waiting for it and when possible will it be avilable in india
regarding ram i want to go for crosair ram 1g x2 ddr ram 400mhz
i want go for ddr2 if posible but i think ther is no motherbord for amd which supports it i think amd doesnt support ddr 2 correct me if i am wrong i am bit confused
about this
graphic card i want to go for nvida 6800 gt 256mb ddr3 ram
what is the diffrance between pci and pcx
and if i go for whcih brand
also i heard about qudro 4000 card whcih build especially for 3d appliction are they available in india what is the cost is it worth
also regarding moniter i want to go for view sony 17 inch flat moniter is it a good choice and ya last but not the least a good sound sustem the card and the speaker budget for the sound card and speaker is 10thousand and i can add a liitle extra i am a avid gamer so would love to go with dolby also what will be the cost of optical mouse i know this are alot of question but i am so confused i am invetsing so much i need the best pleaese try and help me and ya please hurry i will be going to mumbai by monday so need all the help i can get
