Old 17-06-2005, 11:50 PM   #1 (permalink)
Default DDR RAM Compatibility
Can I install a 400 Mhz DDR RAM on a motherboard which supports 266 Mhz DDR RAM.
vinayasurya is offline
Old 18-06-2005, 12:07 AM   #2 (permalink)
yes but it will run at 266 only
means their will be no performance upgrade due to 400 ram
Happy Computing :lol:
krishnathelord is offline
Old 18-06-2005, 12:36 AM   #3 (permalink)
dOm1naTOr's Avatar
U can make it run a 333 MHZ, if Ur mobo supports it. Most mobo (which doesnt support DDR 400) supports DDr333. So try it.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 19-06-2005, 12:31 AM   #4 (permalink)
intel 845 supports 333 hz memory but only some mobo by okverclocking
